Did you try blank password when you are prompted to enter the admin password on the Safe Mode logon screen? If not please try it, most pcs admin password is blank (empty). Good luck. Thanks for using FixYa.
A couple weeks ago, I didn't remember my Windows logon passwords. At last, my workmate Aaron advise Windows Password Reset 9.0. The beneficial program successfully assist me access to Windows. You could Search Windows Password Reset 9.0
A week ago, I did not remember the Windows login passwords. At last, my workmate John suggest Windows Password Seeker. This beneficial app successfully assist me get back into Windows. You could Search windows password seeker or check out their official website: http://www.passwordseeker.com
A windows administrator account is a user account that gives full access
to the machine.
If you forgot windows admin password, how could you break
windows administrator password and gain access to your admin account?
Here
is how to break windows administrator password with Windows
Password Recovery software
Step 1: Download and install SmartKey
Windows Password Recovery software from SmartKey official site
Step
2: Burn Windows Password Recovery software to CD/DVD or USB flash drive.
Step
3: Breaking the lost or forgotten windows administrator password.
Only
need 3 simple steps. Your windows administrator password has been
broken.
A Windows Password Reset Disk could do all the job for you, it can reset your lost or unknown Windows password safely and quickly without login, you can create a Windows password reset disk with the tool Windows Password Breaker, then use it to reset your password.
You can create a Windows password reset disk to reset your password. Follow this 5 easy steps:
1. Enter a computer that can link to Internet. Google "Any windows password reset 7". Download and install the software on that computer.
2. Run the software and create windows password reset disk by follow the instructions.
3. Eject the created CD/DVD and insert it into the locked computer.
4. Reboot the locked computer (it's necessary for you to change your locked computer's BIOS setting to make it boot from CD drive) and then follow the instructions to reset login password.
5. Now login Windows and set a new password.
There are many ways can help you reset windows password .Just follow these steps:
Method 1: Windows XP and further versions also provide another method to recover forgotten password by using ""Reset Disk"". If you created a Password Reset Disk in past, you can use that disk to reset the password.
Method 3:
There are a lot of tools and utilities that can be downloaded and used to recover, reset, retrieve or reveal windows password. However, I've tried a couple of these utilities through the years and my favorite is the windows password key 8.0. This utility is used to reset password of any windows versions.
1.Login to a computer that can link to Internet. Download windows Password key from and install it on that PC. Note that: there is a .ISO file. Burn the .ISO file to a CD or a USB flash drive.
2. Insert the newly created CD/USB to the locked computer.
3. Reboot the locked computer and press'F2'or'Delete'to enter your BIOS setup and then you will see the instruction
It is easy to use,so you really don't need to worried about if you have lost windows password
Here are the steps involved to Hack the Window XP Administrator Password .
Wait its not over read the rest to find out how to Hack the Window XP Administrator Password
A Brief explanation of what you are currently doing here is
Your are nagivating to the windows system Directory where the system files are stored. Next your creating a temporary directory called mkdir. After which you are copying or backing up the logon.scr and cmd.exe files into the mkdir then you are deleting the logon.scr file and renaming cmd.exe file to logon.scr.
So basically you are telling windows is to backup the command program and the screen saver file. Then we edited the settings so when windows loads the screen saver, we will get an unprotected dos prompt without logging in. When this appears enter this command
net user password
Example: If the admin user name is clazh and you want change the password to pass Then type in the following command
net user clazh pass
This will chang the admin password to pass.
Thats it you have sucessfully hacked the Window XP Administrator Password now you can Log in, using the hacked Window XP Administrator Password and do whatever you want to do.
Here are the steps involved to De Hack or restore the Window XP Administrator Password to cover your tracks.
Or simply go to C:\windows\system32\temphack and copy the contents of temphack back into system32 directory click Yes to overwrite the modified files.
Via internetbusinessdaily.net
Note To administrators: You can block the entire password change thing just a little tweak in the local security policy (control panel->administrative tools,works only for administrators group) will disallow any change in password even if u r the Admin (u can put a number of other restrictions too), but be cautious to give other users limitted accounts. After you have done this, the above Screensaver technique will fail.
Update: Christian Mohn points out The Above method is is possible only if you have Local Administrator Privileges. My fault for not checking it up before posting.
Update: The above Method only works if the system is FAT/FAT32 – because of the updated “user rights management” in NTFS – file level rights etc. This does not work on a system using NTFS.
Top 5 Tools to change or recover your admin password:
http://pcsupport.about.com/od/toolsofthetrade/tp/passrecovery.htm
Remove/reset lost Windows password you can use Windows Password Rescuer, it can reset/remove Windows 7/vista/xp/2008/2003/2000 password instantly.
I highly recommend [Daos Password Recovery Bundle 2012].[Daos Password Recovery Bundle 2012] is an all-in-one password recovery software, which recover password for Windows, Excel, Word, Access, PowerPoint, Outlook, RAR/WinRAR, ZIP/WinZIP, PDF etc. Over 70+ types of passwords can be recovered instantly.
