the beeps are diagnostic beep codes and the sounder should not be disconnected,
count the number of beeps then refer to my chart.will tell you what problem is
2 battery voltage too low =fully charge min 8 hours
3 volts too high =contact dealer
5 scooter in freewheel or Brake trip=chech in drive then turn on
6 throttle wig wag faulty or not in center when turning key
7 throttle or speed pot wireing or faulty
8 motor faulty or wireing poor /disconnected
9 battery pack pads and terminals coroded .replace them £2 eachn from pride or controller faulty ..replace
Advisory the analog battery guages on these regulary go faulty and read over full get electrical friend to check battery volts 12.8 to 13volt =fully charged
Most automobile batteries are lead acid which should have a standing voltage of about 12.6V fully charged at 70 degrees F. To test a battery first it must be fully charged. If fully charged a good battery will stay above 9.5V while cranking engine. Most part stores will charge and test batteries, starters and alternators. To be sure your alternator is properly charging start the engine and turn on the headlights and blower fan to add electrical load. Voltage should be over 13.2V at idle and under 15V with a known good battery. If not check the larger wire bolted to the back of the alternator for loose connection and continuity to the battery. If ok check fuses. If all are present and check good most likely the alternator is bad and needs replacement, although it is possible on many modern automobiles to have a powertrain control module (PCM) be the problem as they serve as the voltage regulator. Most late 90s and newer GM and Chrysler do. If all else fails have a professional check it to be sure. Hopefully this will answer the questions of many. Good luck ??.
11.3 indicates that your staring out with a low battery.
a fully charged battery should be at least 12.5 volts before you even start the bike.
Once the bike is started the voltage meter should read 12.8 + volts at an idle.
Once the bike is reved to 2000 RPM the voltage meter should read 13.75 - 14.80 Volts.
I would start withe a good battery. Have it load tested before you install it to ensure it is a good battery. Your local auto parts store load test them for free.
Is there any indicator lights ON showing the fault condition?
This could indicate that the battery has a low charge. Even if you switch off the mains supply and it switches over to the battery, the UPS may shut down after a short time as the battery power (charge) runs out.
If the battery is more than 3 years old then it may be due for replacement.
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement.
2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue.
3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries. Please refer to the section pertaining to Battery Life.
Battery is fully charged motor works but does not catch rear wheel to turn
