Question about Electric Currie EZIP 500 Scooter
When i charge my ezip 400 electric scooter the charger has a green light on it, but when i disconnect the charger from the scooter the scooter shows a red light indicating that the battery is low, is my charger broken or do i need a new battery for my scooter?
Posted by oscarcl10 on
eagle
    New Friend:
  • 4 Answers
I'm having the same problem. checked fuses and both are good. going through the wiring harness to look for shorts. have a bad feeling the micro controller died, that is the little plastic box with metal fins on it under the seat post behind the batteries ******* to the frame. i can bypass the micro-controller and connect one 12 volt battery directly to motor and runs full speed. somehow it is wired with 2 - 12 volt batteries in series to give 24 volts and them the processor cuts back down to 12 volts to run the motor. not sure why this is engineered this way? still working the problem. what sucks so far is that the micro controller is encased in resin so it is virtually non repairable.
* Update added.
Found these wiring harness for sale online scooter stores and on ebay. I replaced mine with some intermediate level adapting the harness to my model scooter and this includes some soldering and wire splicing changing power connector heads off old harness to new harness to fit bike. Works great.
Posted on Mar 08, 2016
aaron_rehnqu
    New Friend:
I have the same problem it is either the orange fuse, the battery or the micro controller.
Posted on Nov 21, 2012
Jh3media
    New Friend:
Did u ever figure out what the salution was
Posted on Aug 23, 2011
  • aaron_rehnqu
    aaron_rehnqu Apr 13, 2014
    it was the micro controller. my guess its fried. you can google
  • aaron_rehnqu
    it and find them (BTW they're around 60-70$)
Hi I have a ezip 400 scooter we just bought a new charger and the charger has a green light but the ezip its charged I was thing maybe its a loss wire or something I got the ezip from someone said if
Push the circuit breaker back in first. The scooter will not move if the charger is connected. If the scooter has sat unused for a long time, the charger will NOT recover the batteries. Charge them individually with an automotive charger until the voltage is at least 11 volts each. May take a 12 or more hours. If you can't get 11 volts after that time then the batteries are gone.
Oct 04, 2014 | Health & Beauty
Scooter won't run
How old is the battery? Most are only good for three years........
Mike
Mar 15, 2014 | Ezip Currie 1000 Electric Scooter, Black
My leo mobility scooter charger light shows green as soon as connected to power it remains green when attached to the battery and does not charge
Hi, that could be because it can't see the battery voltage in most cases or at worse the batteries refused to charge, or your charger has called it a day , check the fuse on the scooter as well...
Regards
www.gewizrepairs.co.uk
Oct 06, 2013 | Electric Mobility 4 Wheel Power Electric...
Quickly loses charge
if its more than a year old scooter thenu have to change the pack of batteries
to check batteries short the both terminals of battery and check the level of sparking
note just a touch of wire from negative to possivte when its fully charged and discharged
Mar 19, 2013 | UPG 12V 10Ah Currie eZip 400, E-400, E400...
My charger light shows always green and it does not charge the scooter.
Usually that means the battery is not able to hold a charge.
Jul 29, 2012 | Razor E100 Electric Scooter
Ezip 150 electric scooter. won't start.
Hi, did you charge the batteries for at least 8 hours? Make sure that your charger has a RED Light When you plug it in, You should see Green light in 4-8 hours depending on the Batteries.
Secondly Your scooter batteries were dead when you got the Scooter, Judging from the fact you didn't get a Charger with it. I would recommend getting a voltmeter and checking the battery voltages. If the voltage is 11-12 volts, then you need new batteries. If this doesn't work check that fuse on the scooter it could be blown.
Apr 15, 2009 | Electric Currie EZIP 500 Scooter
Electric scooter problem
Yes, you will need to get a charger based on the number of 12 volt batteries in the Scooter. I recommend TNC SCOOTERS to buy the chargers. Very good service and lower than most prices.
Dec 17, 2008 | Electric Currie EZIP 500 Scooter
Electric Currie EZIP 500 Scooter Logo
2,007 people viewed this question
Top Electric Toys Experts
Lawrence Oravetz
Mike Stager
Mike Stager
Are you an Electric Toy Expert? Answer questions, earn points and help others
