20 Most Recent Electric Currie EZIP 500 Scooter Questions & Answers
Did u ever figure out what the salution was
Electric Currie... | Answered on Mar 08, 2016
Make certain the Batteries are IDENTICAL to the original. Any change of the Voltage, Current, or Amps will damage the motor or starter. Check all connections to see if they are properly set and Plus is to Plus and Minus to Minus. Check the Ground wires. Make certain all wires are insulated well, no cuts, peeling, cracks, or holes. Technically speaking, if you do not have test equipment like a VOM (Meter) you cannot check continuity (for shorts) and leaks.
If you are satisfied that we are tryting to help you, rate the person accordingly.
Electric Currie... | Answered on Apr 02, 2014
Mine too
Electric Currie... | Answered on Oct 26, 2013
I narrowed my problem down to the throttle after checking the controller, battery and charger and it didnt look easy to remove the throttle so I thought what if its just dirty contacts? So I grabbed my bottle of rubbing alcohol tilted the scooter and poured it into the throttle while twisting it. NOTE: turn switch off !! Flammable liquid!! so i twisted back and forth about 20 times to clean contacts and left to let the alcohol evaporate . Went back in an hour and it worked!! That fixed it!
Electric Currie... | Answered on Jun 21, 2013
Hi, did you charge the batteries for at least 8 hours? Make sure that your charger has a RED Light When you plug it in, You should see Green light in 4-8 hours depending on the Batteries.
Secondly Your scooter batteries were dead when you got the Scooter, Judging from the fact you didn't get a Charger with it. I would recommend getting a voltmeter and checking the battery voltages. If the voltage is 11-12 volts, then you need new batteries. If this doesn't work check that fuse on the scooter it could be blown.
Electric Currie... | Answered on Oct 03, 2012
Electric Currie EZIP 500 Scooter Logo
42 questions posted
Top Electric Toys Experts
NOEL
NOEL
ray gallant
Are you an Electric Toy Expert? Answer questions, earn points and help others
View Most Popular
Electric Toys
  • Electric Toys
Most Popular Question
batteries dead but when charger plugged
  • Toys
