The flashing green indicator is telling you (and the notebook) that the battery is almost fully charged, but then by switching immediately to flashing orange, the status has changed to "battery charge is low". This is not normal behaviour and probably indicates a serious issue with the battery. My guess is that the charging is initiating some kind of rapid battery self-discharge. Ref - Knowledge Base
Notebooks will power up and work without a battery just fine. Ref - Laptop Battery Basics dummies Try to operate yours this way. This will eliminate the battery from the loop as a potential cause of the BSODs you are seeing.
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
If your laptop was sitting on a bed, soft chair or something similar it probably just got too hot. Let it sit for a few hours before attempting to power it back on.
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Yes, the seven flashes mean that the tachometer setting has not been programmed. If you hooked up a tach wire (green with orange stripe) to an uncommon coil or injector wire, then you have to program tach: turn ignition on, press and release programming switch three (3) times. The parking lights will flash once to confirm. Turn ignition off. Press and hold programming switch. While holding the programming switch, start the vehicle. The parking lights will flash to confirm that the remote starter is getting a tach signal from the vehicle. Continue to hold the switch for approximately 15 seconds.The parking lights will continue to flash while holding the switch. Release the programming switch. The parking lights will come on solid for one second, then go off. The tach is not programmed. Turn ignition off. Test system.
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
remove the SD Card and the batteries. Wait for half an hour and then insert two new batteries. Do not put the SD card in as yet. (Waiting for half an hour or more allows the camera to reset itself).
