AT&T Siemens S46 GSM Cellular Phone Logo
Posted on Aug 29, 2017
My Siemens Aqua-Stop dishwasher is not working correctly. All of the cutlery and crockery are not being cleaned or dried on any of the Auto Wash cycles. I have cleaned it with special cleaning agents and I have cleaned out the drains. Also, do you know how to reset the diswasher and is the computer board meant to be on or off - when I went into the menu, it was off.
1 Related Answer
Anonymous
  • Posted on Feb 01, 2009
SOURCE: siemens se26t550gb/25 dishwasher
Turn the washer off. While off press and hold the 35 degree economy wash button. Keep it pressed while you switch the washer on. You can now by pressing the 35 degree button select the volume of the beep or continue to press it until no beep is heard and that will be it off.
1helpful
Dishwasher tablet does not dissolve so crockery not clean
Hello, M Cruse -
There are several situations which can result in the dishwasher detergent table not dissolving completely.
First, make sure your dishwasher detergent tablet isn't the kind that has to be removed from a cellophane type wrapping before placing in the dishwasher. I mention this because my husband does not always purchase the same brand of dishwasher detergent tablets. Some are not the kind with plastic which dissolves in the hot water of the dishwasher.
I think the information here:
https://removeandreplace.com/2015/05/15/dishwasher-not-dissolving-detergent-or-tablet-how-to-fix/
covers all the reasons why the dishwasher detergent tablet may not dissolve completely.
We have the problem that the detergent dispenser often "traps" the tablet. We reside in a rental and the landlord has not chosen to replace the dishwasher with a newer model, so we just toss the tablet into the bottom of the dishwasher.
Note: I think purchasing a gel dishwasher detergent would be better, but The Husband likes the tablets. Sigh . . .
Best wishes.
Feb 04, 2018 • Dishwashers
Whirlpoo l
Probably because the locked up setting needs to be removed or changed. I have never owned a dishwasher. My advice is to remove the dishwasher and sell it. Then soak your dirty cutlery and crockery in hot soapy water in your sink for about twenty minutes, then wash them yourself. Don't be lazy. You have to load and unload a dishwasher anyway.
2answers
What places that water can pick up contaminants in the water cycle?
the filter, the salt tray. mains water supply if there has been any work done in the last few weeks. broken seal or one that is not fully sealing the unit. heater is not working at full heat this usually kill's 93-99% of germs etc
Wash cycle not completed
Lights 1 and 3 indicate that the filters are blocked.
Check water flows through the spray arms onto the cutlery - indicated by wet cutlery.
If dry - recirculation pump is probably blocked
I have tried EVERY piece of advise offered...clean both arms, filter at bottom, rinse all crockery/cutlery before placing it in Bosch, use a dishwater-cleanser on weekly base, check the water pressure, got...
If it is just glasses and coffee mugs that it refuses to wash maybe you should stop trying to wash these items in this dishwasher.
Could it have to do with the location where you put them? Maybe the direct water jet has a blind spot there while the reflected dirty water concentrates there. That may have to do with the shape of the vessel. I am just trying to make sense out of this unusual behavior. (I am thinking of some remarkable properties of parabolic and elliptic surfaces.)
1helpful
Lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
2helpful
Dishes not clean
hi friend,HOW TO GET THE BEST FROM YOUR DISHWASHER
Always follow the manufacturer's instructions and read the directions carefully on detergent, rinse aid and salt packaging.
Cleaning your machine about once a month will remove any grease and lime scale deposits which can build up on the inside of the machine. Special dishwasher cleaning detergents are available which are used when the machine is empty. These cleaners will often leave a fresh smell in the dishwasher too. If you want to have that fresh smell all the time, use a dishwasher freshener. These are usually supplied as hanging tags, which should be carefully positioned away from any moving arms. A freshener is essential if you load during the day and then run the machine at night.
WHAT ELSE CAN I DO TO GET THE MOST FROM MY DISHWASHER?
Cleaning your machine about once a month will remove any grease and lime scale deposits which can build up on the inside of the machine. Special dishwasher cleaners are available which are used when the machine is empty. These cleaners will often leave a fresh smell in the dishwasher too. If you want to have that fresh smell all the time, use a dishwasher freshener. These are usually supplied as hanging tags, which should be carefully positioned away from any moving arms. A freshener is essential if you load during the day and then run the machine at night.
LOADING
These items can be washed in a dishwasher, with the following guidelines:
Glassware - Any ordinary glassware and ovenware such as Pyrex. Do not wash lead crystal glasses unless they carry a "dishwasher safe" label.
Tableware - Most everyday crockery is safe. Bone china usually has under-glaze decoration and should be safe. Avoid antique or hand-painted and over-glaze decorated items. If in doubt, check with the manufacturer.
Cutlery - Stainless steel and silver cutlery are normally suitable for machine washing, but it pays to rinse off any acidic food before loading to prevent any corrosion and, if possible remove the cutlery immediately after the cycle, to avoid prolonged exposure in a humid atmosphere. Do not mix steel and silver cutlery in the same basket and wash bone or wooden-handled items by hand.
Plastics - Check whether they are dishwasher safe and do not place in the lower rack, where the heating element may affect the plastic during drying.
Pans - Stainless steel is ideal for dishwashers. aluminium can be washed in the machine, but may discolour during the rinsing. If in doubt, remove aluminium pans before the rinse cycle.
Always wash cast iron and wooden handled items by hand
WHY DOES MY MACHINE HAVE A WATER SOFTENER?
If the water is soft (i.e. does not contain calcium particles), the detergent will work more effectively and there will be less streaking on dishes. Hard water can also block the washer jets with lime scale and cause deposits on heating elements, which will reduce the cleaning efficiency, increase electricity costs and shorten the life of the machine. All dishwasher manufacturers (Bosch, Miele, Siemens) and detergent suppliers want you to get the best results from the machine - and soft water is one of the most important factors in achieving this. The way to ensure water remains soft is to regularly top up the reservoir with granular salt.
Three in one salt tablets do not activate the water softener.
HOW MUCH SALT DO I NEED TO ADD?
Your machine may have a float indicator or a warning light to tell you when salt needs adding to the water softener. Often float indicators are difficult to see, and there is no accurate guide as to how much salt you need to add. Quite simply, just add granular salt to the reservoir until it won't take any more!
The softener will use the salt to replenish itself each time you wash. As an approximate guide, you should do a full top up about once a month. If your machine doesn't have a warning light, a good way to remember to check and / or top up is to do it on a regular day of the month (e.g. the first Saturday or the 15th)
CAN I USE ORDINARY TABLE SALT?
No. Table, cooking, rock and sea salts may contain additives that can actually increase water hardness. Also, the fine consistency of some of these salts mean they are likely to clog when wet. Always use granular dishwasher salt because it is very pure and is the right consistency for use in your machine.
Granular salt is the ONLY type of salt that should be used to regenerate the softener. Be aware that some varieties of ‘dishwasher salt’ use Dead Sea salt. This variety may contain minute insoluble organic matter that may adversely affect the resin within your softener over time. If you are in doubt about the origins of the salt, ask the retailer or manufacturer.
WHAT DETERGENT SHOULD I USE?
All modern dishwasher detergents are formulated to work specifically in dishwashers. On no occasion should ordinary washing up liquid be used, as it will cause excess foam, which can result in a leak. If it is accidentally used, sprinkle ordinary salt into the chamber to disperse the resulting suds. Then rinse away the excess salt before using.
There are 3 main types of dishwasher detergent - Powder, liquid or gel and tablets. Which one you choose will be down to personal preference, but most people find tablets very convenient, although using powder is usually more economical and liquids are less abrasive on more delicate items.
WHAT IS RINSE AID?
Rinse Aid is added to a special compartment in the machine and a very small amount is released during the final hot rinse cycle, to reduce the formation of water droplets on crockery etc and so ensures that the water dries away properly and evenly to avoid leaving smears.
Dual action detergent usually contains rinse aid, which is released at a different rate to the cleaning agent and so helps reduce smearing etc without the need to add separate rinse aid. Some 3-in-1 tablets contain an ingredient, which has a 'salt action', which also helps to improve cleaning, but NOTE this is not a substitute for adding salt to the water softener.
The salt action takes place in the cleaning chamber of the machine, but does not actually replenish the water softener. Research has shown that whilst 3-in-1 detergents do clean dishes effectively, their performance is improved by adding salt to the water softener reservoir.
As the performance of machines can vary, as can local water conditions, it is always best to follow your manufacturer’s advice. Some manufacturers advise that if you have unsatisfactory cleaning performance eg white powder residue, poor drying or dirty dishes, then you should return to using three separate products ie detergent, rinse aid and granular salt. Be aware that if you have not been filling the salt reservoir and relying on the salt in 3-in-1 tablets, then it may take a few cycles to re-generate the softener.
hope this helps u
please rate me..................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 • Dishwashers
Not coming out clean
I'm guessing from your post that your cutlery is the only thing in the dishwasher that is not getting clean, but rather with that nasty coating when you go to empty it. The reason for this phenomenon doesn't lie in a problem with the dishwasher, but rather a simple chemical and physical reaction between the dishwashing liquid (or powder or tablet), heat from the dishwasher's dryer, and the metal on that set of cutlery. The bleach from the dishwashing detergent will work very hard at getting your glasses, bowls, and everything glass and/or plastic clean and sparkling because it contains bleach in its ever-proprietary mixture of citrussy goodness. Unfortunately, metals and bleach, combined with heat are NOT a good combination! The best advice I can give you in this case (again, assuming that everything else in your dishwasher is looking fabulous and that your cutlery is the only thing that is not) is to wash your cutlery by hand with regular dish soap in the sink and do not put them in the dishwasher. Of course, it's easier to just stick all of that stuff in the dishwasher and not wash it by hand! It's why you bought a dishwasher in the first place, right? But if you want your cutlery (especially if it's GOOD cutlery) to look good and perform well, your best bet is to wash it the good ol' fashioned way...In the sink.
I hope this helps! :) Let me know if you need anything else that I can help with.
Sep 21, 2009 • Dishwashers
1helpful
Miele dishwasher cleans most items, leaves pans dirty
water may not be hot enough...check thermostat in waterheater.
Mar 13, 2009 • Dishwashers
Top AT&T Cell Phones Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
