If the power supply has the 6 pin connector to plug into the video card, you should have no problem using this card with your current setup..
i currently use a GeForce 9800GTX+ with about the same pc as you have using a 600w power supply and no issues what so ever, generally the video card power supply requirements will be stated on the side, but i'm pretty but it requires a 450w or 500w, so you should be fine.
Testimonial: "Thanks I'll Try.. it.. ^_^ I'll just comment back if it works.. once again thanks.. ^_^"
