The flood protection device has activated. This is caused by a leak in the machine. It can also be caused if you are not careful when checking the drain pump,water may have gone back into appliance and activated flood protection device. If this is the case Tip machine forward,water in base of appliance will run out, and appliance will work. If Fault reoccurs then you have a leak.
We had tried everything, according to the manual to deactivate the flood protection device & had given up, resigned to the fact that I would have to pay £175.00+++ to get a miele engineer out. I searched the web and came up with the same question. We followed the 'tip machine forward' tip to drain water out, even though we had tried to water pump out any water in our previous attempt & HEY PRESTO IT WORKED FIRST TIME ....... THANK YOU VERY VERY MUCH
