Bulb on license plate is out and cruise control. Is this a fuse or an electrical problem (2004 chevy cavalier) ?This happened at the same time when I tried to change the bulb and this did not fix the problem. Checked fuses too. Is there any fuses under the hood that I dont know about or in the trunk?
The two problems should not be related to one another. The the fuses for the park lights and the cruise control. The license plate bulb is wired along with the rest of your park lights. If the rest of the park lights are working then check for power and ground at the bulb holder. If you have both there, check the bulb and the fit again. If no power or ground is there you will have to trace the wires. If the fuse is not blown to the cruise control, more information is required to trouble shoot any further.
Testimonial: "Ok..I will see if it is the wiring. I think it is strange that the cruise worked until changing the bulb on the plate.Thanks"
