The power supply to the hoover is fine and I've dismantled it and checked that there are no blockages. The red lights appear for Bag being full and on the Brush indicator, when turned on the machine just hums and nothing else happens. I did check the brush and have removed this and replaced it. I also checked that the drive belt was attached and this seems to be in order. Any thoughts? Thanks
I'm not sure about this one but, as nobody else has picked it up, I'll give it my best guess. You say the machine just hums - by which I take it that there's no suction at all. I wonder how old your Sebo is... if it's seen a lot of work, it's more than likely that the carbon brushes in the motor have worn out and need replacing. This is not a difficult job, but you do need to be comfortable tinkering with machinery to attempt it yourself. Otherwise you will need professional help. If you want to do it yourself, post a reply here and I'll give you step-by-step instructions.
