I have a FPD1960 monitor that will not turn on. I opened it up and it appears the power circuit board may have been damaged because it has a black discoloration on in. Part no: G1167980G. Can I replace this component? What is the cost?
The most common problem with the FPD1960 is a failure of the power supply board pictures here.
The capacitors overheat and bulge causing them to fail. If you can solder then you can do the repair yourself. Here is a link to a parts kit: http://www.ccl-la.com/catalog/product_info.php?cPath=21_30&products_id=206
I hope this helps, if so please rate my solution.
BuddyMc
Since Gate does not make the monitor, you need to get the name of the maufacturer as printed on the board. You can send me the pictures if you want: [email protected] and I do some research.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
