New to me used 755p-1.07-SPNT. Have done hard reset. World Clock alarm works fine. Calender alarms bring up the notification screen behind Keyguard, but only rings 1 time regardless of the number of Repeats selected in Sounds & Alerts - Calender.
There could be a number of reasons for this happening. Does the clock run only on batteries or batteries and electricity? It could be the age of the clock. The way the clock has been taken care of and the type of environment it is in for example too much dust. If the clock runs on batteries, have the batteries ever leaked and been left in the clock? Take very fine sandpaper and very gently sand the contacts of the clock where the batteries go, dust with a small dry paintbrush and use good quality batteries.
Good morning to you Ijust know onething about setting alarms and that is. To do it in the right order. When I set mine (nokia)firstly I find software in software there is a clock. New alert- alerts- world clock I click on new alert then on the screen fill in what is asked. I can also do this trough the calender- check if this works for you.. also check if alarm sound is on if not put it on. all the best Kolbrun
to set the alarm, press and release the "alarm" button; then press and hold the "set" button until the hour begins to blink. press "adv" until the hour AM or PM is correct;now press and release "mode" so that the minutes begin to blink. Set the minutes using "adv"; now press and release "set". Finally, press and release "adv" once to bring up (or remove) the alarm icon. Then press"alarm" once to return to the main display.
To set main display, press and hold "set" until the hour begins to blink; press "adv" repeatedly until hour AM or PM is correct. Now press "mode" so that the minutes blink, and use "adv" to get the minutes right; then press "mode" so that the next item begins to blink; use "adv" to advance until it is correct, then press "mode" so that the next item blinks, and so forth until you're all done. Finally, press and release "set".
The solution is a follows; If you have any legit alarms already set, disable them before proceeding
1) As soon as the unwanted alarm goes off , look at what time your phone says it is and make a note of it. (if you know EXACTLY what time it goes off at, then go to the next step)
2) Goto Start -> Clock & Alarm -> Alarm
3) Set the alarm time for the exact time from step #1. Set alarm to On.
4) Click Done, done, and done
5) Goto Start -> Clock & Alarm -> Alarm
6) Change the alarm to Off.
7) Click Done, done, and done
That's it, the alarm should now be disabled for this unwanted alarm, if you have multiple unwanted alarms, repeat this procedure for each.
