Homelite Consumer Products 7 Amp Blower/Sweeper Logo
Posted on Apr 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to replace primer bulb( rubber cracked) can't locate part anywhere. Help !!!!- Homelite Blower Model BMV160
vince janis
Level 3:
  • Master 718 Answers
  • Posted on Apr 08, 2010
vince janis
Master
Level 3:
Answers
718
Questions
Helped
256494
Points
1742
Go to pats small engine parts yuo should be able to find it there good luck!
Model 26b wont start. the fuel bulb is not filling up when pushed
Some ideas on what I think is a HomeLite 26B Blower although this info will apply to any 2cycle.
1- a cracked/leaking primer bulb. Most likely
2- a broken/cracked fuel line in the tank.
3- the fuel filter. Least likely
Easier to check is the bulb. If you check the line and filter and find either one bad replace both. You'll thank me later.
Sep 14, 2017 • Garden
How do i remove the primer bulb on my homelite mighty lite 26cc blower
The primer bulb should be attached directly to the carburetor. There will be a plate with 4 screws, once on each corner, which you will have to remove to get the primer bulb off of the carburetor. You can find replacement primer bulbs at PartsBuggy.com.
I have a handheld blower/vac: The primer bulb is new and will not pump fuel,not even fill the bulb. I checked the fuel lines to make sure they were correct.(homelite)
I was working on a neighbor's homelite chainsaw and I replaced the primer bulb, it was not intuitive, and I hooked up the lines backwards. Also if you are replacing the primer bulb, maybe you have old fuel lines that are deteriorating and need replaced. Did you check the in tank fuel filter? If it looks dark, it may be time to change it.
I hope this helps get you going again.
5helpful
5helpful
2answers
My Homelite Mighty Lite 26b Leaf blower has a punctured primer bulb. Homelite doesn't list the part number. Model number UT08520A Can you help? Thanks, Ed Mckinney,Tx
Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
1helpful
How to replace primer bulb on homelite blower
remove the two screws, lift metal oval plate off, remove cracked bulb and replace with new bulb, put plat back on with screws prime new bulb. Note when you remove screws whole assemblage will want to come apart. Good Luck Tim
Oct 24, 2010 • Garden
2helpful
2answers
Redmax blower older model does not start, tried a few drops of gas in spark plug port and it started. but stalls after fuel in burned off, any help would be appreciated, djk913
Carb. problems sounds mostly like the carb needs to be thoroughly cleaned out, drop fuel bowl and hit openings with a tiny steel wire and carb cleaner also check the diaphram, sounds like its cracked/dried up.
My primer bulb cracked, can I replace it?
Yes, in fact event he DIY centers have parts like that available off the shelf or ACE Hardware. You will need the specific model number to ensure you get the right part or bring the old part with you.
1helpful
Primer bulb is cracked on my Homelite Blower/VAC Model HB-180 Gas is leaking, I need replacement parts. Blower purchased in 1990
www.homelite.com to buy parts online
1.800.242.4672 customer service #
both will give you your local shop. Home depot also sells homelite products.
Apr 24, 2010 • Garden
4helpful
Blower will not prime and start
Primer bulb has hole in it or fuel line cracked.First use needle nose pliers to crimp fuel line just before primer ,dont use to much pressure and see if bulb will hold vacuum when you press it.If it wont hold vac either buld has hole or valve in primer is defective.If it does then you need to crimp off fuel line feeding carb and see if primer holds vac.If it does not then you need to replace powervalve inside carb.
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
