Question about Homelite 'Yard Broom' Leaf Blower
Leaf blower won't stay running
When first starting, it runs at a reduced speed (choke open), for a few minute and then quits altogether. Is this the result of bad fuel or the wrong mixture, or something completely different ? Wade
Posted by wbourdon on
roeb
  • Homelite Master
  • 819 Answers
Replace fuel with clean fuel with proper oil mix. Also the carb. could need cleaning or diaphragm could need replaced. One thing you would need to check that will not cost much but may save you a lot of trouble is the muffler. Check the muffler for obstructions and remove the muffler and check the exhaust port for carbon buildup.
Posted on Apr 13, 2009
D Recev
    New Friend:
Two cycle engines have a habit of vibrating enough to cause bolts to come loose. You could have a leaky head gasket or crank cover gasket and still be getting excellent compression at the spark plug. If there are leaks then the piston won't be able to create enough suction on the up stroke to pull the gas/oil mixture from the carb at low rpms
Posted on May 09, 2013
Anonymous
    Problem Solver:
I had the same problem with my leaf blower.I disassembled to find the flywheel key was sheared.I instslled a new key and reassembled. It ran fine after that.
Posted on Apr 24, 2009
Will not start after warmed up and sits for 5-10 minutes
Check that the spark plug is not fouled
Check to make sure your mixing your fuel
correctly & not adding too much 2 cycle oil
Adjust the idle & high speed on the carb
when you first start it up cold
Gas can not be more than a month or two old
& has to be regular 87 octane
Aug 12, 2014 | Garden
Why my Aztek wont stay running
Put a Fuel Gauge on the Fuel System, see what is happening if the Pressure is dropping below 40 PSI, there is your answer. If it stays, then you have an Electrical issue.
Jul 20, 2014 | 2004 Pontiac Aztek
Automatic choke problems
Yes, spring may have broken or maybe it just needs adjustment. There is a high idle cam that makes the card idle higher when the choke is closed or partly closed.
Dec 20, 2017 | 1982 Porsche 911
Small gas engine dies when choke full open
I have attached a diagnostic sheet to help you determine what is wrong.
Jan 21, 2014 | Weedeater 2 Speed Gas Blower FL1500LE ()
I have a 24" snowblower that surges after 1 minute of running, after 3-4 minutes stops and will not restart until several hours later, does the same thing over and over
This sounds like a choke issue. Do you have a choke on that engine?
The purpose of a choke is to allow for a varying air:fuel ratio depending on how hot the engine is. A cool engine needs a more rich mixture of fuel to air. Once the engine warms up, it runs best with more air. The Choke is a mechanism that allows the operator to manually adjust this mixture. Generally, the choke is closed to start a cold engine, then is opened in 2 or 3 stages as the engine warms up. As the operator, as the engine starts to run smoothly, you would actuate the choke to the next notch, changing the fuel:air ratio so more air is mixed in with the fuel. It's probably best to give the engine a few minutes to warm up while you progress through the choke stages until it's fully open providing the best mixture for operation prior to beginning to clear the snow.
If you follow that process and the engine stalls when the choke is opened, then you need to clean your carburetor.
Oct 18, 2012 | Garden
Runs at different speeds and quits
Try changen battery. Might be a short.Was it left in the rain (noy good)
Aug 12, 2012 | Worx GT WG150 10 in. 18 Volt Cordless...
My 1996 VF 750 C Magna starts fine with the choke open. After a minute or so as I reduce the choke and try to open the throttle, the engine just stalls out. Cannot seem to get the throttle to control
I think you are mixed up. The choke is usually closed to start a cold engine and opened once the motor warms up. The choke is closed to restrict the air flow and make the mixture richer in fuel. You can't open a choke that's already open. It's stalling because it's starved of fuel. Either a blockage or the fuel pump is not supplying enough gas.
May 06, 2012 | 1996 Honda VF 750 C Magna
Engine quit when stopped at stop light. Acted as if it was choking then died. Tried restarting. Turns over strong, no start. Thought maybe no gas. Added gas after about 30 minutes. Started first try....
Sounds like the fuel pump is going out. Replace the filter first, as it's only $10. If that doesn't fix it, then it's probably the pump, which is $250.
Jun 10, 2011 | 1993 Jeep Grand Cherokee
Engine starts and runs a few seconds and quits
It sounds like your carburetor needs cleaned. If you started it for the first time without emptying the old gas, you may have had dirt particle's that had settled at the bottom of the tank. This would explain why it had ran the day before. If you need further assistance on how to clean the carb., just let me know.
Jim
May 24, 2009 | Remington Electric Chain Saw
Honda em2500 starts, runs 1 minute, quits and will not restart
If the oil level is low it will do this, but I also know this to happen when the oil is very cold (thick) an won't fow back own o the crankcase where the oil sensor is. The slow return results in a low oil level. My solution is to start it, when it dies wait a couple of minutes and retry... after a few starts, the oil will warm up, thus flowing back down faster and it then will run. Another option is to use a thinner oil ie;5-30w.
Apr 19, 2009 | Electrical Supplies
Homelite 'Yard Broom' Leaf Blower Logo
6,978 people viewed this question
Top Homelite Garden Experts
roeb
Randy Schumann
Randy Schumann
Nick Olsen
Are you a Homelite Garden Expert? Answer questions, earn points and help others
