Weber grill three burner. New tank of propane but #1 burner hardly lights. When turning on the other burner the flame goes out
The new style
OPD valves have a small brass ring located in the female
fitting on the LP tank. Over time this ring can work loose and then it
does not allow the male fitting to fully depress the OPD valve thus
reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This
should solve your problem
IF not you might want to remove the cap
(white) on your regulator and try slowly adjusting the regulator, make
small adjustments and try the BBQ My Weber if I set the front and back
burners to MED I get right at 350 degrees in 60 degree outdoor temps.
Adjusting the regulator will take some time to get it right but If it is
not your tank it is most likely your regulator out of adjustment
