I need to know how to connect the 12 v dc power to the unit as I lost my power cable. The unit has a 7 pole connection at the back. I would like to know wich connections are to be used to connect the + and - .
I really hope that someone can help me out here.
Greetings
Stan (Holland)
[email protected]
SOURCE: jrc 1000
Hi , I have a JRC 1000 with manual if it can helps ( in English and french but i ma in france. You can also use the installation manual of JRC 1500 available on internet under pdf format , very similar ( same screen and operating interface )
[email protected]
SOURCE: draw down is to high
found my fault not i the power cable in, but the interconnect to radar dome..approx 50mm from radar screen a break in the wire, found it just by wiggling the cable.. the set wont power up if the interconnect not connected or is faulty
SOURCE: Hello, I need a power cable for my JRC 1000. How
Hello there,
I also need this very same power cable. Did you find one already? maybe you can tell me wich one of the 7 input connections is the + and - DC power connection so I can connect this thing myself with a home made power cable. Greetings. Stan (holland)
[email protected]
Thanks!
SOURCE: need to know how to
As you look at the back of the display unit, the power plug has 7 connection posts.
Top left is pin 1 Bottom Right is pin 7
Pin 1 ..... + 12v
Pin 2 ..... - 12v
Pin 7 ..... Boat Ground
Rob
