You will have to shim the scope, use a piece of 35 mm film, It works good, 2 if you need it, if you at extreme measures, you will have to shim the base. You can look through the barrel of a bolt action rifle and see what you will hit at 100 yards, just prop up the rifle in a box or a vise, site down the bore at a target, mailbox, streetlight, then bring the scope to that point, check your barrel again. This will put you on paper at 100 yards. Hope this helps.
