Casio FX-115ES Scientific Calculator Logo
Anonymous Posted on Mar 14, 2010
How do i do a number 'to the power of 1/2 or 2/3? cheers Brad
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Mar 14, 2010
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4675965
Points
21596
Power 1/2 is the same as square root: You can use the square root key to the left of the square key.
Similarly power 1/3 is the cube root. You use the [SHIFT][Square root] key sequence.
Power 2/3 is the square of the cube root, or the cube root of the square.
More generally, you can use the universal power key, marked with X with a raised white rectangle. It is between X square and log.
Ex: Calculate 15^(2/3)
15 [X with raised rectangle] 2 [/] 3 [)] [=]; the result is 6.082
The last parenthesis closes the left parenthesis introduced by the calculator.
Alternatively you can use the cube root and the x-root selections available under the MATH menu.(selections 4 and 5)
how do i do a number 'to the power of 1/2 or 2/3? - 6629153.jpg
Testimonial: "Great- thanx :-)"
My Canwood Stapler/Brad nailer 2 in 1 has a broken trigger. I want to replace it. Any vids or pdf out there? Cheers!
Try youTube.?
If there's no specific one's for that model
there will definitely be something similar which you can use to identify the principles behind how you'll need to proceed.!
Year of manufactor
Hi Brad, Without the gun brand name and model number nobody can help.....CHEERS..
May 05, 2016 • Optics
My brad nailer will shoot one brad then nothing until I take out and reinsert the brad, then one shot, etc.
Hi Robert:
These tend to be very reliable tools but they do have some quirks.
1) They need to be oiled regularly so if you don't have an automatic oiler, a couple of drops in the air inlet before you connect the first time every day will save you grief.
2) The brads are fed by spring pressure, and the magazine and spring assembly have to be kept relatively clean. Use air to do a decent job. (WEAR SAFETY GOGGLES)
3) The firing mechanism likes a decent amount of pressure, not enough and mis-fires are common. DO NOT EXCEED MAXIMUM ALLOWED.
4) The hammer assembly and slot MUST be clean and not binding. Use the allen wrench that came with the gun and dismantle, clean, and re-assemble making sure that there are no rough bits that are creating the problem.
DISCONNECT FROM THE AIR SUPPLY BEFORE YOU START THIS MAINTENANCE
CHEERS!!!!
1helpful
My ken wood dishwasher model number is KDW60 S12 and when I set it on cycle 1 hr for lightly soiled loads it takes approx 2and a half hours. Cheers Brad Brown
A great dishwasher! I'm not that familiar with that model but there is probably a logic(computer) board in that model that governs the cycles and it is defective. What you could try is to open the circuit breaker or turn off the power for a couple of minutes to the dishwasher. If it resets properly that may prove the problem. If it works properly after doing that it will be a logic problem and may reset. If it does work it may happen again and the board will have to be replaced. Sounds like an electrical spike (lightning or something similiar) may be the culprit. Just a good educated guess. I would be interested if you could post the outcome..
Brad nails crooked in bostitch
Have you inserted the correct Brad Nails? What is the code of brads you have inserted? Is the tool jammed?
Solent Products Air Nailing and Stapling Supplies
How to load brads into stanley tre 550 electric staple/brad nail gun
HOW TO USE YOUR ELECTRIC STAPLER/NAILER
TO LOAD STAPLES
1. Unplug tool, (fig. 1)...(place on/off switch in "off" position, (fig. 2).)
2. Place on/off switch in "off' position.
3. Select proper staple length.
4. Use only staples identified by stock numbers on next page. Substitute staples may cause jamming.
5. Hold tool upside down. (Squeeze latch and pull, (fig.3).)
6. Drop staples in channel, legs facing upward. Push latch back in to lock in place, (fig. 4).
TO LOAD BRADS
2. Use only brads identified by stock numbers on next page. Substitute brads will cause jamming.
3. Look for the image of a brad nail on the front side of the tool (fig. 5). Load brads into this side only.
4. Hold tool upside down (Squeeze latch and pull, (fig. 3).)
5. Drop brads into the channel, tilt the tool so the brads lay against the channel wall, (fig. 5).
Push the latch back in watching that the brad strip does not fall over.
6. Use High/Low power when driving brads.
TO STAPLE OR NAIL
1. Make sure the on/off switch is in the "off" position, plug stapling tacker in.
2. Turn tool on by switching to position 1 which is the "on" position and hold firmly against work surface to
engage safety mechanism.
3. Apply adequate pressure on the top of the knob (fig. 6.) while the trigger is pulled.
You can find the figures mentioned above at the following link:
http://bdk.force.com/FAQ/servlet/fileField?retURL=%2Fapex%2FPKB_Article%3Fid%3DkA0C0000000CdtPKAS%26brand%3DStanley%26returl%3D%252Fapex%252Fpkb_search%253Fbrand%253DStanley%2526mode%253D0%2526model%253D%2526sortby%253D0%2526terms%253DTRE550&entityId=ka0C0000000CdqqIAC&field=File_1__Body__s
A 1 1/4" brad nail only penetrates 1/2 inch
Hi, There should be a power adjustment on the top of the driving head. Make adjustments there, and the penetration should improve.
--W/D--
I dropped my bostitch brad nailer and it won't hold air, I took the end off and a washer fell out and I can't see where it goes, but the compresser keeps going and going and won't shut off, I can feel air...
Go to Stanleybostitch.com and type in your model number for a breakdown and parts list. If you want give me the exact model number and I will do more research for you.
Bcm 1996 voyager
Have you tried your local wrecking/recycling/junk yard. they often have them at a fraction of the cost.
Robert
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
