Panasonic Viera TH-46PZ85U Plasma TV Logo
Posted on Mar 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic plasma viera tv will not auto tune, can not pick up any signals at all. All cables are plugged in correctly. Model number TH-P46G10A
Chi Chu
Level 3:
  • Panasonic Master 8,457 Answers
  • Posted on Mar 13, 2010
Chi Chu
Panasonic Master
Level 3:
Answers
8457
Questions
0
Helped
2823077
Points
26282
Reboot all cables,satalites,and telicoms boxes.Like unplug,replug the box an hour later.Let the boxes up grade software,go to ur tv menu setup rescan all channels again well get them back.Ur signal not there after that, than ur Tuner Signal board is dead.Need it replaced.
2answers
Can i connect my panasonic viera th-42px8ou plasma tv,to my vista desk top? my tv has hdmi on it,my vista tower also says it has 1 hdmi connector on the back of it
You can buy an HDMI to DVI adapter (around 20$) to connect your HDMI computer cable to your TV. You will need separates audios cables, right and left, to bring the sound to the TV.
1helpful
2answers
Just bought a 42" panasonic
On your remote, click menu, then setup, then external devices, then input labels. Here is a link for manual:
http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX80U
My panasonic viera tv suddently is not picking up
The most common reason for a digital TV to read "No Signal," or to constantly suffer from frozen screens is poor cable connections. First thing you want to do is to check to make sure they are all correct, and that you are using cables rated for your system. Next is that you want to remember that the fewer lines you use, the stronger your connection will be. If your connections are all good, check to see if you are using splitters. Imagine your cables are actually water lines. It would be easy to see how thin your flow will be if you have a half a different different directions and lines through which you are forcing it to flow. If you can limit the number of lines you have connected, then your signal will be stronger. There are often a number of different ways to wire a sound system and peripheral components to your home theater. Sit down and review it. Anyplace you can eliminate a line (or mess of lines!), the stronger your signal will ultimately be when it gets to your TV's receiver.
If you are using cable and none of this works, chances are you have a "leak" in your line somewhere which needs to be reviewed by your provider. Be sure to remove all splitters and all such diverting sources before they arrive, though, as if the problem is found indoors, you will very likely be charged for this as a service call.
How to connect Panasonic Plasma tv with satelite hookup to playstation 2
U can't hook the satelite signal to the PLaystation 2.The satelite hook up to the main in the Antana input.The playstation 2 must use the RCA cable came with the Playstation 2 hook up in any Audio,Video in put in the the tv.Tune in what input u hook up like 1,2,3,extra..use ur Playstation 2.
Color Adjustment Problems - Reception in Black and White
satelliteand cable TV is only comes in black and white.
this a HTML type plug or a coaxial
select menu and source
very weird... should default to colour
if no luck try plugging in a desk top digital box tune using that
TH-42PX20 TH-50PX20 Operating Instructions High Definition Plasma ...
ftp://ftp.panasonic.com/television/om/th-42px20_en_om.pdf
Panasonic plasma tv
complete guide here...http://www2.panasonic.com/consumer-electronics/support/Televisions/VIERA-Plasma-HDTVs/model.TH-42PZ80U
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
