Hi, My Frigidaire dishwasher Fdb4315lfc2 door opens too far, past the level point. It appears some sort of stop is missing. I cant find it in the charts. Any ideas?
There are two springs that support the door and control the rate it falls and stops at. They are located at the base of the door. One on the left side and one on the right.
Slide the machine out. Usually held with screws directly into the underside of the counter. You may have to lower the unit by turning the feet. Most of the time you can just slide it out.
Look on the sides and you will see the springs. One or both will have come off. They should be hooked to a slot in the door hinge and the other end to a hole in the frame of the unit.
Over time they can become over stretched. If you put them back and the door drops too quickly and stops with a jar then replace the springs. Spring are springs so you can get them at a hardware store or parts supplier.
Hope this helps. Please rate this answer if it helps you.
Hello friend, thank you for your post!
I understand that your Frigidaire dishwasher door is falling open too far. It could be a potential issue with your hinges or door. I would highly recommend reaching out to a professional for further assistance in properly diagnosing the issue with the door. If you have any further problems please feel free to reconnect. -Matt
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
