Cameras Logo
Posted on Mar 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MicroSD atchment write protect
I have an olympus tough 8000 and am using the microSD attachment... when i turn on my camera it tells me that its write protected but i cant find any switches on my card?????
Megasom
Level 3:
  • Master 699 Answers
  • Posted on Mar 07, 2010
Megasom
Master
Level 3:
Answers
699
Questions
0
Helped
235204
Points
2067
The microSD card has no visible write protect tab that you can access: you need to use a Micro-SD to SD/mini-SD adapter that usually comes with your Micro-SD card and use the ON/OFF sliding tab on the adapter to disable or enable the wiite protection on your Micro-SD card: test the access via the adapter card before removing it.
Hope it helps: let me know how you go!
Not charging not turning on/off lens window open. Where can I take this to get it repaired? Old model but camera barely used for 1 year.
Olympus cameras have to be sent back to Olympus themselves which unfortunately they charge for, you can get the address from their website
1helpful
Olympus Tough-8000 Flash Charging Warning
It could be the capacitor in the flash is defect, but it also could be your battery (batteries) are to low on voltage. ALthough when that happens the camera should switch of.
There could be all other kinds of defects, like oxidation of some contacts or a broken flat cable in the camera, But my guess is the capacitor does not charge to the correct voltage.
Olympus Tough 8000 wont charge
Rechargeable batteries will fail if stored for long periods in a partly charged or in a zero charge state.
You need to replace this battery with a new one.
Olympus 8000 turns on then turns off again, wont stay on
This happened to mine suddenly as well. I bought a new SD card and presto! All better. I think these things fry SD cards, cause this is my 3rd card.
My Olympus Tough 8000 charges up to a blue light but when I unplug the charger and switch it on, it just beeps multiple times and switches straight off. I've only used it for a week and it's a new,...
i have the same problem too. Mine is mju tough 6010 and it just beeps and switch off. The metal cover in front of the lens won't open. Mine is just 1 month old.
My olympus tough 3000 will not turn on, when i turn on orange light at the top just stays on but nothing comes up on the screen
.' i have a problem with my camera olympus u tough 3000, when i turn it on..it is okay but after 4 or 5 seconds it will automatically shut off.. help me please... if what should i do.. what is the best solution to fix this..
Battery charger says charged. camera will not turn on
Hi there i can 't get your these word." camera charger is blue, used battery and new,". Please let me know the battery is new or or its old? If its old then the battery life is finished. Thats why he can't store the power.
Thanks.
? software problem - not responding
Remove the card and the battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
