ASUS R1E-B1 Tablet PC Logo
Posted on Feb 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Laptop is not playin any sound?, it just says no audio output device is installed what is wronng
Lara Douglis
Level 3:
  • ASUS Master 229 Answers
  • Posted on Mar 27, 2016
Lara Douglis
ASUS Master
Level 3:
Answers
229
Questions
0
Helped
240885
Points
1375
I was also having such kind of problem with my asus laptop. I tried to replace the sound driver. but no better luck. so i've contacted to Asus tech support on toll free number- 1-800-585-2494 and Found the solution for my laptop. Get the best Asus Computer Support by Asus Support . hope they will help you to fix your problem related to asus.
Anonymous
Level 3:
Brigadier General:
  • Master 5,158 Answers
  • Posted on Feb 21, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
5158
Questions
5
Helped
2066244
Points
15105
Go to www.asus.com click on support and locate the laptop model that you have. find the correct audio driver and download and install it. that should fix your sound issue
Heck fedrick
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 5 Answers
  • Posted on Apr 05, 2018
Heck fedrick
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
5
Questions
Helped
795
Points
44
If your Laptop having the Sound Issue. Then you can talk to the Experts of Asus Technical Support . They offer you the best solution regarding any technical Issue. And you can also reach the website to read the Asus related blogs. Surely they will also help you.
http://www.helpquicky.com/asus-customer-service
laptop is not playin any sound?, it just says no - 6960a69a029c176eb60146c3ec30437c-nuft52k1oqdz5vkwkfnjb2dd-1-0.jpg
1helpful
No sound except through headphones
The fact that the device produces audio output through the headphones indicates that the audio system is operable up to the headphone jack. Therefore, the fault must lie in the internal speaker, the wiring between the jack and the speaker, or the jack itself. Most likely, the internal speaker has gone belly-up and needs to be replaced...
1helpful
No audio output device is installed
HI, there might be an issue with your audio card.
  • click on start
  • right click on computer then properties
  • click on device manager
  • then check the audio information, if there a ? mark the drivers are not installed
  • if there is a ! mark, the drivers are corrupted. and you have to reinstall it again
Cheers!!!
No audio playback device installed
It's means there's no sound device installed, this could be audio drivers problem, please reinstall it. You can download the driver from here if you have problem with yours. Fujitsu Lifebook t1010 drivers Please select the corresponding drivers for your operating system type. Good luck. Thanks for using FixYa.
No sound in my laptop
There are 4 ways you can download and install audio drivers :
1.From Device Manager
(1).Click Start, type Device Manager in the Start Search box, and then press ENTER.
(2).In the Device Manager dialog box, expand Sound, video, and game controllers.
(3). Right-click the device, and click Scan for hardware changes.
You should see a message that a hardware device is being installed. Additionally, the uninstalled audio device is now present in Device Manager.
(4).Close the Device Manager dialog box, and then determine whether you can hear sound.
2.From the motherboard or installation CD - If your computer came with a motherboard CD, the audio drivers should be on the disk.
3. From manufacturer's website - If you don’t have the CD go to your computer manufactures web page to search for updated sound driver software. Read the instructions on the download pages carefully before installing.
4. Microsoft's Windows Update feature : If there are no updated sound drivers available, use Microsoft's Windows Update feature. Connect to the Internet and try the following items until Windows Update opens:
(1).Click Start, and then click Windows Update (if it is listed).
(2).Click Start, click Settings, and then click Windows Update (if it is listed).
(3).Click Start, click All Programs, and then click Windows Update (if it is listed).
(4).Go to Microsoft's Web site and click Windows Update from the Downloads menu.
1helpful
IBM x41 1866-9GU does not have an audio device (sound card) installed. I need to find the right one that will work with this laptop and get it ordered and delivered. Do you know which model I need?
Are you certain it is not just a driver issue? If the right audio driver is not installed, the errors will also indicate that there is "no audio device installed".
More info here: http://www.pcauthorities.com/pc-errors/no-audio-device-in-windows
If you have the original CD< you can look for the audio drivers there. If not, check the IBM support website, or use a driver finder program to auto-detect and download the right driver.
No sound after clean install
i had the same problem, then i look for toshiba viturle sound wont work so try to install soundmax AC'97, coz R10 used Intel 82801DBM board. just search for intel 82801DBM Drivers
2answers
No Sound..Missing Multimedia Audio Controller
Go to the toshiba, and download the audio drivers for your laptop.
In the device manager, right click and uninstall the device.
Reboot
Reinstall the audio drivers.
Do it by the downloaded file, rather then the Windows Wizard.
If the downloaded file does not have a setup.exe or an install.exe, go to the device manager, and choose "Update drivers". Point it at the folder you downloaded the drivers to, and let it do the install.
If there is a problem after that, please post any error messages.
Lost my sound
go into device manager and try updating the audio drivers are inabled and on then update drivers, Other wise you can go into the system restore in accessories and restore you system to just before you lost you audio drivers, that should get you up a hearing sounds now, If not just let me know and I will find another solution. OK Thanks again and Happy Hoidays
2helpful
3answers
Audio Not working.
hi. i had the same problem all audio worked just when i pluged earphones in sound was going from speakers not from earphones. well i had before some problems with windows what may cause it. dont know why but after pressing Fn+F5 the earfone output started work corectly. probably some hardware initialization failure
hope it will work for u
Top ASUS Tablets & eReaders Experts
k24674
john h
Ngoro
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
