For that you need to go to your display property .
If you have windows then go to start menu->controlpanel->display->settings .
Then set screen resolution to 1440*900 .
Then apply and ok.
But make sure graphic driver installed and working fine if graphic driver is not installed then you can not set resolution for that you need to install graphic driver then you can adjust screen resolution in display property.
Let me know if you need further assistance.
Thanks for using Fixya.
Hi
Please do the following
1) Switch on your PC
2) Right Clickin the middle of the dekstop and click on properties
3) This will open a display properties window, at the top there will be a tab called settings
4) In this windows half way down there will be a option entitled screen resolution, this slider can be pushed to the left or right push to the left until the figures at the bottom read 1440 X 900 pixels
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
I hope this helps.
If this Answer goes some way towards helping to resolve
your Query, Problem or Fault, please take the time to Rate it. Doing so helps
Solution Providers, like me, better understand the needs and the point of view
of Askers, like you, and guides us in exploring the best ways to provide the
most comprehensive, useful and high quality Responses and Solutions we can. If
you need further help, please do not hesitate to post another Question or add a
Comment to this Question.
Thanks for using FixYa.
