20 Most Recent eMachines EZ1601-01 All-in-one PC 18.5' Widescreen Intel Atom N270 1GB DDR2 160GB Intel GMA... PC Desktop Questions & Answers
Go to the Crucial site. They make memory and their site will scan your PC, then tell you how much memory it will take.
From there, it will also give you an idea of how to open your PC to install the new or additional memory.
www.crucial.com
Good luck,
-a.
eMachines... | Answered on Apr 06, 2016
You probably have a bad power supply. An easy way to tell is if you plug another device (any electrical device will do) into your same power source (a power strip for instance) and if you have power to that device, you need a power supply. A decent repair place will charge $70 or so
eMachines... | Answered on Sep 07, 2014
When Windows is updating you basically need to wait for it to finish before you power down or you will find yourself in that endless loop of updating. You may need to reboot into safe mode by pressing F8 as windows is staring up, then let it run updates and again reboot.
eMachines... | Answered on Sep 06, 2014
Unless you do this for a living, you should let a pro do it.
eMachines... | Answered on Jul 25, 2014
go to www.microsoft.com and see the technical specification test for to see if your equipment has the software +hardware availaable for to maintain the instalation for w. 7God bless you
eMachines... | Answered on Mar 29, 2013
All-In-One desktop computer disassembly isn't usually posted.
Technology is still new enough, and required skills needed, dissuade the imparting of this information.
Plus eMachines is about worthless for support info anyway, lol!
A) Construction, and design of the machine dictate a laptop type of environment.
All the hardware components are crammed into one tiny box, with very little cooling inside, and the monitor is attached. (LCD screen)
Free Service Manual,
http://www.manualslib.com/manual/232919/Acer-Ez1601-01.html#manual
Just go to the top, and click on the page number you want, or go page by page;
OR,
Scroll to the bottom right below the first page, and click on the Green -
Download Manual (154 pages, 9.48Mb)
Going inside the all-in-one means you had better wear an ESD wrist strap, and have the alligator clip attached to a good ground source.
(Electro Static Discharge)
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Wear an ESD wrist strap, or prepare to use your all-in-one for an expensive doorstop, if you don't.
Cost averages from $3 to $6. One example,
http://www.radioshack.com/product/index.jsp?productId=2103245
[ I connect to an unpainted surface, of the metal frame if an open, empty desktop computer case.
You can also set a large metal serving tray, (Unpainted), on the table you're working on, and connect to it.
Or a large metal knickknack. (Unpainted) ]
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
For additional questions please post in a Comment.
Regards,
joecoolvette
eMachines... | Answered on Oct 17, 2012
One way is to mount it in another computer as a secondary drive and format it there (might be easier).
eMachines... | Answered on Apr 11, 2012
have you tried plugging the screen into another PC? Is the power etc connected and not loose? Is there a power light on the front? If you can connect remotely try changing the resolution to something lower incase the screen cannot handle high res
eMachines... | Answered on Sep 01, 2011
Hi
Start by checking what EMachines sat is the maximum RAM and RAM Clockspeed the motherboard can support (as it's an XP machine, I suspect it may be 2Gb max). Then make sure you buy 1 stck of the correct RAM (there seems to only be 1 RAM slot).
Disconnect from mains power.
LCD Monitors, TVs and All-in-One PCs have a dangerous internal working environment, containing several Capacitors that store a gigh charge capable of seriously injuring or even killing an inexperienced repairer.
If, for economic or educational purposes, you are determined to do the repair this yourself, you need a large sheet of paper on which to sketch a screw location diagram of the rear of the LCD Panel.
The first step is to remove the rear cover pf the LCD Panel, often the stand will also have to be removed as well. This is almost always not straightforward. (see review on: http://reviews.cnet.com/desktops/emachines-ez1601-01/4505-3118_7-33721162.html)
Use the diagram to intelligently map the locations of the different types an sizes of srew you come accross while opening the rear cover.
Be very careful to remove every retaining screw before trying to lift the cover off (there are often several hidden srews and it is easy to miss one and snap off part of the cover or the frame it connects to). Do not use force - if the cover will not lift off easily, look for more retaining screws.
Once the cover is off, you are looking for laptop type RAM Memory Modules, with parrallel side clips that, when pulled outwards with the fingernails of both thumbs allow each Memoey Module to spring up at an angle, enabling to slide it out of its socket.
To replace the memory slide each new module in the correct orientation (there is a notch that only permits the corect orientation) until it is fully docked in the socket. Then press down until the two side clips catch and lock into place.
Now place the cover open face up on a desk or table and carefully place the LCD panel onto the cover, before connecting, powering up and testing the computer with its new RAM, before reassembling it.
Hope this helps.
eMachines... | Answered on Aug 22, 2011
Download the sound card drivers at the eMachine website for this model of computer. Then install.
eMachines... | Answered on Nov 04, 2010
For instructions on how to remove or change the Windows User's password, please click on this link :-
Normal 0 http://www.fixya.com/support/r4335021-remove_xp_vista_password
eMachines... | Answered on Oct 01, 2010
Your CDrom/DVD will have a very small hole at the front of the panel which will allow you to insert a paper clip into it. This is the emergency manual eject button. Make sure your PC is powered down or the disc may come flying out. Simply push a straightened paper clip in the hole.
eMachines... | Answered on Aug 30, 2010
Hi! Please try this. Remove the battery of the pc and unplug the pc from power source then press hold the power button for 10secs. this should drain excess power and will reset the system. Put the battery in again then turn on the pc and see how it goes. You should to this as a first course of action and please write back on the progress. Hope this helps and have a good one!
eMachines... | Answered on Aug 14, 2010
Do a complete re-install from the CD.
Having setup several POs terminals they all seem to support the default printer attached to the PC I set up a couple with epson 40 line dot matrix printers and monarch thermal printers as well as secondry laser printers and full tracking dot matrix for reports all conected to the same terminal
eMachines... | Answered on Apr 23, 2010
Most likely. The power supply will fit, but Dell machines tend to be skimpy on the extra connectors as they are custom-built. The Video card is PCIe 3.0 standard. I could not get spcifics on your manboard, but I'm fairly certain that it is not up to the 3.0 level. PCIe is backward compatible, however. Just don't expect 3.0 level performance if you mainboard only supports the 1.1 standard. Basically you are racing the Ferrari in your driveway.
eMachines E... | Answered on Dec 11, 2013
Hello
You may visit a computer tech to clean the cooling fan,it needs to be clean to avoid overheating or damaging your motherboard..
eMachines E... | Answered on Dec 05, 2013
the manual can be found here: http://asuseee.free.fr/dl/EZ1601.pdf
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
eMachines E... | Answered on May 19, 2012
eMachines EZ1601-01 All-in-one PC 18.5' Widescreen Intel Atom N270 1GB DDR2 160GB Intel GMA...  PC Desktop Logo
Popular Tags
26 questions posted
Top eMachines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
E eMachines
  • E eMachines
Most Popular Question
computer will not power up
  • Computers & Internet
