Hope this will helped you fixing the time of your Citezen divers watch. Just foolow the instruction below.
Change your Citizen watch's time zone without actually moving the clock hands. On the digital display, change the city that displays on the watch, which sets the time to the different time zone. The Citizen also has a calendar, timer, chronograph and LED lights. Since it is an Eco Drive watch, it is solar powered so you never have to replace the batteries unless its backup power source dies. Difficulty: Easy
Instructions
Pull the setting knob (crown) out one "tick" for setting mode.
Set the mode hand to "WT-S."
Pull the crown out one more "tick."
Press the top button on the right side of the watch for the city setting mode.
Press the lower button on the right side to "SET" the city.
Turn the crown to select a different city, which changes the time zone.
Push the crown all the way back in to finish setting the time.
Press the center button on the right hand side of the watch 1 time you will see settings watch time & date appear in the display.
Press the bottom button on the right side of the watch1 time to get into the TRAINING SETTINGS FUNCTION.
When you see TRAINING SETTINGS in the display press the center button on the right side of the watch once.
You are in TRAINING SETTING mode.
Press the bottm button on the right hand side of the watch 3 times until you see
ZONE LIMITS displayed.
When you see ZONE LIMITS displayed press the center button on the right side of the watch 1 time to enter into the ZONE LIMITS FUNCTION.
Now, you should see the lower end heart rate limit number blinking.
To adjust this number use the top button on the right hand side of the watch to increase this limit or lower button on the right hand side to decrese it.
When you have it set where you want it press the center button 1 time to save that setting.
Now you should see the upper limit number blinking.
Follow the same steps to set the upper heart rate limit.
When you have pressed the ceter button to set the upper limit you have completed setting the heart rates limits and the display should read: LIMITS SET!
QUICKSTART - SET THE TIME 1. Push the bottom right hand button until the mode hand indicator points to TME. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Select the time zone on the digital display by pressing the upper right button or the lower left button. 4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time. 5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00. 6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time. 7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time. 8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour. 9. Push the lower right button back in.
SET THE CALENDAR 1. Push the bottom right hand button until the mode hand indicator points to CAL. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Select the time zone on the digital display by pressing the upper right button or the lower left button. 4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month. 5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date. 6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year. 7. Push the lower right button back in.
SET THE ALARMS 1. Push the bottom right hand button until the mode hand indicator points to AL1, AL2 or AL3. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Select the time zone on the digital display by pressing the upper right button or the lower left button. 4. Pull the lower right button out one click. You will see ON or OF flashing on the digital display. Press the lower left button to turn the alarm on or off. 5. Press the upper right button. You will see the hours flashing. Press the lower left button to change the hour. 6. Press the upper right button. You will see the minutes flashing. Press the lower left button to change the minutes. 7. Push the lower right button back in.
SET THE TIMEZONE 1. Setting the time zones allows you to add or remove cities on the digital display or switch between daylight saving and standard time. Begin by pressing the lower right button to move the mode hand indicator to SET mode on the bottom dial. 2. If the hour or minute hands are obscuring the digital display, press and hold the upper left button for three seconds. This will cause the hour and minute hand to retract to the 12 O’clock position. 3. Now pull the lower right button out one click. You will see the digital display flashing. Press the upper left button to select SET to display the city or OFF to not display the city. Press the lower left button to turn summer time on or off. Summer time is indicated on the lower part of the digital display. Daylight savings time must be manually set for each city. 4. Pressing the upper right button will allow you to scroll through all the cities. After setting, push the lower right button back in.
USING THE TIMER 1. Press the lower right button to move the mode hand indicator to TMR mode on the mode dial. 2. If the hour or minute hands are obscuring the digital display, press and hold the upper left button for three seconds. This will cause the hour and minute hand to retract to the 12 O’clock position. 3. Pull the lower right button out one click. You will see the minutes flashing in the digital display. Change the minutes by pressing the lower left button. Once you have set the minutes on the timer, push the lower right button back in. 4. Pressing the upper right button starts and stops the timer. 5. Press the lower left button when the timer is stopped to reset the timer to its initial preset time.
USING THE CHRONOGRAPH 1. To use the chronograph press the lower right button to move the mode indicator hand to CHR mode on the mode dial. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3 .To start or stop the chronograph press the upper right button. If you press the lower left button it will display the split time for 10 seconds. 4. When the chronograph is stopped press the lower left button to reset back to zero.
SET THE TIME ZONE 1. Setting the time zones allows you to add or remove cities on the digital display or switch between daylight saving and standard time. Begin by pressing the lower right button to move the mode indicator hand to SET mode on the bottom dial. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Pull the lower right button out one click. You will see the digital display flashing. Press the upper left button to select SET to display the city or OFF to not display the city. Press the lower left button to turn summer time on or off. Summer time is indicated on the lower part of the digital display. Daylight savings time must be manually set for each city.. 4. Pressing the upper right button will allow you to scroll through all the cities. After setting, Push the lower right button back in one click.
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
1. Push the bottom right hand button until the mode hand indicator points to TME. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Select the time zone on the digital display by pressing the upper right button or the lower left button. 4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time. 5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00. 6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time. 7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time. 8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour. 9. Push the lower right button back in. SET THE CALENDAR--
Please do accept the solution if the issue is resolved or else revert for further assistance.
If the store you purchased the watch at has not set the time to the correct time zone then obviously the different time zone (UTC in this case) that is showing on your digi face isnt exactly helpful....
Best bet is to go to the interactive watch instructions on www.citizenwatch.com to follow along on how to get it into your own time zone.
Just type in your model number exactly JR3060-59F into the search field. On the right side of the page is the Get Technical Info link..click on this choice. Now on this page is the next link...right side at the bottom of the list> Interactive setting instructions. The page changes again and you see the choice menu. Find Zone Settings...click and follow the instructions (note there is sound to it so turn your speakers on if you have them)
The movement in this Elgin is made by Citizen. After you change the battery, you need to reset the hands so that the watch functions properly. Select chronograph function with lower-right button. Then pull-out the same button. Push the upper left button to select the UTC, hour, and minute hands. Then use lower-left and upper-right buttons to make sure everything is aligned to 12:00 position. After setting the hands to 12:00, push in lower right button. Now you can set the time by selecting the SET using the lower right button. Pull out the same button and choose your time zone to set.
I think I have the same watch and was just looking here to see if I could find how to stop the alarm going off every hour! However, I think I do know how to change the time: press the mode button three times (the first one brings up something like the stopwatch, the second brings up what may be an alarm time). On the third press you should get the time appearuing with the seconds flashing on the far right of the display. You can then change the second by pressing the"start" button. To change the minutes or hours, oress the "reset" button until they start flashing and use the start button again. pressing the reset button again will bring up the date to change. keep pressing until nothing is flashing any more and poress mode and it should bring you back to the current time. hope you can follow this and it works!
good morning! to set your watch is you need to press the adjust button up to three second after blinking the digit on you watch press the mode button to select the digit that you want to change, to change the digit use the two button on the right side of your watch,after setting press the adjust button once and your watch is gona be normal,thank you ! god bless !.
