Samsung SGH-a727 Cellular Phone Logo
Posted on Jan 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Center key, left, right, up, down, 2,5,8, not
Please help me with my samsung a727 keys not working
center key, left, right, up, down, 2,5,8, not working anymore
Anonymous
Level 2:
Scholar:
  • Expert 150 Answers
  • Posted on Jan 14, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
150
Questions
0
Helped
46226
Points
248
New keyboard membrane required (keyboards often come in one piece, and you can get whole rows failing particularly with liquid damage
Good Luck
4 way navigation key and left and right keys locked when slide up but work when down
please give more detail on your problem
and a problem like this should be fixed by giving your phone to the samsung customer care service center
7helpful
2answers
How do I lock keys on TB7220U? The previous advice did not work - there are no blank keys.
Access the ISU (installer setup) menu by pressing the system key from the main screen then press and hold the two keys on either side of the center for approximately five seconds. Hit next until you find 0670 and then change the value to 4. http://www.forwardthinking.honeywell.com/related_links/thermostats/commercial_pro/install/62_0221.pdf On a side note, this information was insanely hard to find.
Need help with samsung a727
you have to down load the driver for it. it's found in the samsung pc studio 3.2.1 if you're running xp other wis you're out of luck kind of. Win 7 will see it and after some kicking it you can get it to be seen, but there is something internal that takes over the phone and ddoesn't let the samsung software connect to the phone. in either situation does it allow you to explore your phone like external storage unit outside of the software.
Set all 3 alarms and they never go off. Big problem since it is my only alarm clock for work and just recently quit working have used for almost 2 yrs
You need to make sure the Ringer is enabled. Here are the instructions:
Alarm Clock
The Alarm Clock tool allows you to set up to three
alarms.
When you set an alarm, the current time is displayed.
When the alarm goes off, Alarm 1 (or 2 or 3, as
applicable) will be displayed on the LCD screen and
the alarm will sound.
1. From standby mode press the Center Select
Key c [MENU], then press the Directional Key
r right twice for SETTINGS & TOOLS, 2
Tools, 4 Alarm Clock.
2. Press the Directional Key j up or down to
highlight an Alarm (1, 2, or 3), then press the
Center Select Key c [OK].
3. Enter the alarm information including:
• On/Off
• Time
• Frequency
• Ringer
4. Press the Directional Key j up or down to
highlight the information you want to set, then
press the Left Soft Key L [Set] to view your
choices.
5. Set information and press the Center Select Key
c [OK].
6. Press the Center Select Key c [SAVE] after
setting all of the applicable Alarm Fields.
1helpful
Samsung SGH a727 forgot password to turn on phone
To reset the handset, to the factory default settings, follow the steps below:
  1. While in standby mode, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Reset Settings (10)
  4. Highlight, using the navigation keys, any of the following:
    • All: Phone, Display, Profile and Alarm settings will be returned to default values
    • Phone Settings: only phone settings will be returned to default values
    • Display Settings: only display settings will be returned to default values
    • Profiles: only profile settings will be returned to default values
    • Alarms: only alarm settings will be returned to default values
  5. Press the center navigation key to check the box(es) of reset settings
  6. Press the left soft key for OK to set the Reset
  7. Enter the password, using the keypad, default password is “00000000”
  8. Press the left soft key for Confirm
  9. Enter the password again to confirm, using the keypad
  10. Press the left soft key for Confirm
  11. Press the left soft key for Yes to reset the handset's settings to the factory defaults
Samsung sgh-A727 and I cant remember the power on password
4helpful
3answers
Samsung Omnia - Main Menu Function key gives a shortcut error.
Assign the key to another function. And then reassign it back to the main menu short cut. It worked for me.
Steps to forward inbox texts to email with white screen problem?
First open your phone. Press upper right (-) key to get menu. Press joystick up 1 time to get Messaging. Press joystick center select button 1 time, then down 1 time for "Inbox" (or down 3 times for email). Press center select 1 time, joystick down 1time for Inbox, center select for first message. Press upper right (-) key for "More", then joystick down 2 times to get "Forward", press center select. Press upper left (-) key to "Continue", press joystick up 1 time to get "enter email addr." Press joystick center select button, and enter the email address you want to forward the message to. After you have typed in the email address, press upper left (-) key "OK" 2 times to "Send", if you normally enter a password, type it now, press upper left (-) key for "OK" and your message will be sent. Hope this helps. -Mike
1helpful
How to send picture msg
Here's how send a picture in a message.
1. Press the Center Select Key
2. Press the Navigation Key to scroll to Messaging, and press the Center Select Key
3. Press the Navigation Key and scroll down to Create Message, and press the Center Select Key
4. Press the Navigation Key and scroll down to New MMS Message, and press the Center Select Key
5. Press the keypad to enter desired text
6. Press Options, by pressing the left soft key
7. Highlight Insert, and press the Center Select Key
8. Highlight Picture, and press the Center Select Key
9. Press the Navigation Key and scroll up or down to the desired picture
10. Press Insert, by pressing the left soft key
11. Press Send To, by pressing the right soft key
12. Press the Navigation Key, and scroll down to desired contact, and Press the Center Select Key
13. Press Send, by pressing the right soft key
You can find this, and other helpful stuff at
this page on the Motorola Support site
Don't forget to rate this solution once you've tried it !
2answers
Help
transfer music from pc to A727
To transfer files using PC Studio, from a PC to the handset, follow the steps below:
  1. These instructions assume you currently have PC Studio. If you do not, please check the Samsung Accessories site to purchase the software.
  2. If the application is not yet installed, insert the CD into the drive on your PC and follow the on screen instructions to install PC Studio 3.0 (version 3.0.1)
    NOTE: DO NOT CONNECT USB CABLE DURING PC STUDIO INSTALLATION
  3. Confirm the handset's USB mode is set to PC Studio by following the steps below:
    • While in standby mode, press the left soft key for Menu
    • Select Settings (9)
    • Select Connectivity (6)
    • Choose Select USB Mode (4)
    • Highlight PC Studio, using the navigation keys
    • Press the left soft key to Save the USB Mode settings
  4. Launch PC Studio 3.0 (version 3.0.1), you will see "Not Connected" in the bottom right corner
  5. Plug the USB cable into both the handset & the PC, you will now see "SGH-a727 Connected" in the bottom right corner (See example below) a727%20connected.jpg
  6. Click on Transfer Files, you will now see the PC Studio Phone Explorer appear a727%20phone%20explorer.jpg
  7. Navigate to the location of the file(s) to transfer then highlight the desired file(s)
  8. Click on To Phone, on the Phone Explorer menu bar (See example above) to copy to the handset
  9. From the Search Folder screen, Navigate to the desired destination on the handset
  10. Click OK to copy the selected file to the handset's memory
PC Studio Checklist:
  1. Make sure your USB or Serial cable is compatible with your phone model. You can always check for the correct data cable by looking at the model number on samsungmobile.com in your phone's accessories section.
  2. If you are using a Bluetooth dongle or IrDA port as your connection, the necessary driver(s) should be provided with their data kit and should be correctly installed and set up prior to the installation of PC Studio.
Hints & Tips:
  • Remember to select file formats and file sizes supported by the phone when uploading files to the phone from the PC.
  • Remember to select the correct destination folder in the phone when uploading files to the phone from the PC (e.g. mp3/aac files-> music folder, jpeg/gif files-> downloaded images folder, 3gp/mpeg4 files-> downloaded videos folder...)
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
