Ur power board have burn capcitors,like puff up or burst open,must changes these capacitors.Know how to solders?Tries Shopjimmy.com,Ebay.com for buying reburbish power board.
Your TV main board is damaged and you need a new one. You can order one on ebay and fix it yourself. Make sure you have the TV model/serial number on the back label of the TV to have the right part when ordering.
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
I'm having the same problem and am about to try this solution. I truly believe this is going to work. I hope this helps!
http://www.youtube.com/watch?v=OsJSzYVUWVA&feature=related
I've seen this problem before with Philips. 6X3X blink was the X-sus or Y-sus boards. In other words, the TV cannot make the picture on the screen properly, so it won't even try and will shut down.
I've also had difficulty getting these parts from Philips (even while being an authorized service center). If you have an authorized service center near you, you might want to give them a try because I don't believe they were too expensive, just hard to get.
