call at customer care of your cellphone service provider for knowing first your PUk number after knowing your puk add to your phone where is demanding after this it's prompted to enter pin as new one only 4 digits after selecting ok its say reenter pin add the last new pin which you putted renter again and after that all work done just press ok or done. your phone is now unlocked. remeber that its always require the new pin if you change or on/off your cell.
Hello
<br />
Personal identification number (PIN), is a secret number that is used to unlock the phone, unlock in the sence of accessing the device you are using. It is made up og 4 digits that is giving to you when you buy a phone number. It comes with your phone number not with the device, so that means you can still use the same pin on different mobiles. But always remeber your pin number because if you lose it then your phone will be probably blocked!
<br />
Following are the some ways to find the pin code:
<br />
Enter the last four digits of your phone number on your cell phone PIN screen. When setting up a cell phone PIN, the default number assigned is the last four digits of your cell phone number for most cell phones.
<br />
Enter 9999, and if that doesn't work try 1111. The number sequence 9999 and 1111 are other standard numbers assigned when choosing a cell phone PIN.
<br />
Shut off your cell phone, take off the back of your phone and pull out the battery. Record the IMEI number under the battery. Reinsert the battery and power on the phone. Enter the last four digits of the IMEI number on the PIN entry screen. The last four digits on your IMEI number can occasionally be the service provider's preset PIN for the cell phone.
<br />
Call your service provider and request the PIN. You will have to prove you are a customer by stating your cell phone number, address and NIC number.
<br />
Hope this helps, if so do rate the Tip.......
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider. PUK codes can be obtained through the following ways -The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider. Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.For details to obtain the PUK code for the SIM card, pleaseclick on this link and follow my instructions. http://www.fixya.com/support/r5705889-puk_code
Hello, Going back to the security location will unlock the unit but in order to reset the pin code, the original pin code must be input. To unlock the unit, it must be sent back to Garmin.
Hello
Hope this helps.
