20 Most Recent Nokia BH-104 Bluetooth Headset Questions & Answers
cara buka kode pengaman nokia 105
Nokia BH-104... | Answered on Jan 30, 2019
  • 1
    Turn on Bluetooth headset and Blackberry hand-held.2
  • Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.3)Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.4)Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.5)Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
  • Nokia BH-104... | Answered on Jan 13, 2017
    frnds...ungaluku Nokia BH 104 la songs kekkanuma..android appsla mono Bluetooth router download pannunga...easya songs kekkalam...enjoy..
    Nokia BH-104... | Answered on Dec 20, 2016
    Hi, to connect nokia bh-104, you will have to use the default code which four zero's "0000" and your done ...
    Have a nice day...
    Nokia BH-104... | Answered on Dec 21, 2014
    SO!! FINALLY! Connect headset to the charger. Wait for 1-2 mins, then HOLD VOLUME UP key + SWITCH ON KEY for.. donno i waited for 30 sec, then looked at redlight and suddenly saw a GREEN LIGHT lightning, but it's so hard to see it. I'll try to do a photo.
    Nokia BH-104... | Answered on Apr 06, 2012
    Ok.. you need to do the following:
    1. Turn the headset off. 2. Turn on the Bluetooth on your iPhone (it will automatically start searching for Bluetooth devices) 3. Press and keep pressing the power button on your BH-105 Nokia Headset until you hear two sounds, the first is the one that notify's you that the Headset is turned on, keep pressing and you will hear another sound (like a beep), once you hear that second sound release the power button on the headset and voilaaa... your iPhone detected the Headset... Cheers...
    Nokia BH-104... | Answered on Jun 04, 2011
    hi
    first hold start button for 8 to 10 second...when it start blinkin then open bluetoth device and click ADD tab. and search your device.when it will appear,it will ask for a unique pass.then choose your pass key.PLEASE MIND THAT THE PASS KEY MUST BE FOUR TIMES ZERO (0000) and then ok.it will connect......
    Nokia BH-104... | Answered on Mar 20, 2011
    Make sure the device is powered on and paired with your phone before trying to send anything.
    Nokia BH-104... | Answered on Feb 28, 2011
    Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
    Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
    Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
    Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
    Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
    Nokia BH-104... | Answered on Feb 23, 2011
    I dont owe one.
    Nokia BH-104... | Answered on Feb 01, 2011
    hi i just had this problem what i did was make sure the nokia headset is turned off then turn it back on holding down the call answer button for 5 seconds untill the light on it flashes green then red which resets the headset then it should connect to the iphone mine didnt even need the passkey which is 0000 hope this works for you
    Nokia BH-104... | Answered on Jan 09, 2011
    you have to check the compatiblity of this device with yout cell phone.
    Connectivity Bluetooth version
    • 2.1 with enhanced data rate (EDR)
    Bluetooth profiles
    • Handsfree profile (HFP) 1.5
    • Headset profile (HSP) 1.1
    if your cell phone has the above features then follow the undermentioned steps.
    you need to search for the device by starting a new search after switching on the bluetooth and make sure that the bluetooth headset BH-104 is switched on.
    once the search is completed and your device is found then pair it.
    after pairing the device you can use it.
    Nokia BH-104... | Answered on Jan 03, 2011
    0000 for pass key . read the manual .
    Nokia BH-104... | Answered on Nov 21, 2010
    Nokia BH-104 Bluetooth Headset Logo
    60 questions posted
    Top Nokia Radio Communications Experts
    Anthony Ward
    Anthony Ward
    Muntejaya Ginting
    Muntejaya Ginting
    Zhareese
    Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
    View Most Popular
    • Nokia Radio Communications
    Most Popular Question
    cara membuka kode pengaman nokia 105
    • Radio Communications
