AcerScan 320U Flatbed Scanner Logo
Posted on Dec 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to replace the power cord. What spec should
Need to replace the power cord. What spec should I be looking for? Power level, voltage, watts, etc.?
Anonymous
Level 2:
  • Expert 70 Answers
  • Posted on Dec 30, 2009
Anonymous
Expert
Level 2:
Answers
70
Questions
5
Helped
28769
Points
179
Output voltage Mordaunt Short MS308
Most makers specify the transformer as a safety part which can only be replaced with a manufactures specified part. Contact them for the correct part. If you can't get one from them, then replacing it with a none recommended part, could pose a fire risk.
What could cause Transceiver to shut when power output is increased over 40 watts?
My first guess would be that you have a bad/poor antenna,coax, causing high reflected power, next would your power source. You will need a 25A or higher rated power supply, with clean 13.5V power to run at the higher power levels. Meter the power supply voltage when you xmt at a lower power level, maby 30w, watch for drop in voltage. If voltage drops (some) at 30w, most likely supply won't hold voltage up at your 40w and higher power levels.
2helpful
HP Deskjet 1056 supposed to be dual voltage...?
What does it say on the "brick" on the cord? Look for power specs on the cord transformer.
Trying to order battery and new power supply for computer 96254
Without the Make, Model of computer It's difficult to help. But a word of advise, Beware of inexpensive aftermarket Batteries and cord/chargers. They sometimes , at best, do not work properly, a worst, can be a fire hazzard. It's cheap for a reason. Be sure to buy the EXACT power specs, Voltage, Amperage. Look to the Laptop Manufacturer for exact replacement. They may be pricey, but , in the long run a better bet.
Need voltage spec.
Power Supply: 12 Watt Universal Power Supply (100 - 240V AC, 50/60 Hz) Average Power in Standby: 7.5 watts Average Power in Standby with Power Saver On: 6.5 watts Average Power while Printing: 9.7 watts
I hope this information has been helpful.
I bought a new panasonic home cinema model number sc-pt480eb-k. Its supposed to be 1000 watts but the output it doesn't match that output at all even with all the speakers on. What maybe the cause of this...
Hype on the part of the maufacturer's published specs.
http://service.us.panasonic.com/OPERMANPDF/SCPT480.PDF
Look at the Power Comsumption spec on page 22. "90 watts"
According to this post, 45 watts...
http://reviews.cnet.com/home-theater-systems/panasonic-sc-pt480/4507-6740_7-34024832.html
It would be a miracle indeed to extract 1000 watts of sustained power in any form, be it heat, light, motion or sound from a unit that uses anything less than 1000 watts of electricity, assuming 100% efficiency. Not to mention the dreadful 10% distortion level they use to get that figure.
To say it pushes 1000 watts is dishonest and preys on the gullible.
1helpful
I Just recently bought this have it hooked up to my Computer through a Digital audio Coaxial cord . The problem is this 600 - Watt system is emitting less power than the 300 watt one it replaced that was...
Audio power is relevant only between the amp and the speakers. Check the volume setting of the source and any audio settings in the PC.
SPDIF is not Red and White. If anything it is a single coaxial RCA connector.
Wattage specs for comparison are pure fiction at this level. 10% distortion fudges the number upward.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RT2910-Home-Theater-Systems-manual/id/23699ag100/t/2/
Defeat any bass enhancement in the source until you figure out the level issue.
I need a new cord that plugs in to charge the batteries,or so i wont need to use batteries they are dead
Here are the specifications for the power chord for your notebook.
417220-001 : AC adapter (65 watt) - Input voltage 110-240VAC, 50-60Hz, 2.4A - 18.5VDC output voltage, 65-watt - Requires a separate 3-wire AC power cord with C5 connector
You can purchase from impact computers
2answers
I need a new power cord for a dell inspiron mini 10 netbook. I THINK it is a 30 watt cord but am not sure. Can I replace the cord with a 65 watt cord?
If you are talking about the battery charger + power cord combination for your laptop, the yes. A 65 watt will charge your batteries faster, and also provide enough power for a docking station and external monitor, if you have them.
Using a 65 watt charger instead of a 35 watt one will not harm your laptop in any way.
1helpful
I need an owner's manuel for a Pioneer stereo power amp SPEC-4. I have a part # ARB-235. I think this amp is a product of the 1970's. Where would I be able to get my hands on the operating instructions?...
You can register with hifiengine.com andfind it and the service manual.
There really isn't a lot to a power amp to be operated. This one differs from most in that it has an input level control and VU meters.
From http://images.google.com/imgres?imgurl=http://www.incomesixdigits.com/spec4/spec4a.jpg&imgrefurl=http://www.incomesixdigits.com/spec4/&usg=__WbFLwPqHXjFHe_P2BCKyTT9CxQY=&h=652&w=1156&sz=526&hl=en&start=2&um=1&itbs=1&tbnid=5SVKh2leUGWXmM:&tbnh=85&tbnw=150&prev=/images%3Fq%3Dpioneer%2Bspec%2B4%26hl%3Den%26rlz%3D1R2ADFA_enUS360%26sa%3DX%26um%3D1
Dynamic 150 + 150 Watts Power Output, Generous High-power Design
The Spec-4 employs DC construction which excludes capacitors from the NFB circuits and uses a dual transistor differential amplifier with a current mirror circuit in the 1st stage. This provides a stable operation and also high gain over a wide frequency range. The pre-driver stage is a class A amplifier circuit with a regulated current circuit for the load. This makes for high-gain amplification with superior linearity. Furthermore, there is an overdrive limiter and power limiter circuit which is designed to protect the power transistors and make for added reliability.
The power stage employs a 3-stage Darlington pure complementary parallel SEPP circuit.
The SPEC-4 delivers Continuous Power Output of 150 watts per channel, min. RMS, at 8 ohms from 20 Hertz to 20,000 Hertz with no more than 0.01% total harmonic distortion.
Completely Independent and Perfectly Stable Left / Right Power Supplies
The mighty power supplies are completely separated for the left and right channels. Also, each channel is provided with two 22,000uF large-capacity electrolytic capacitors and large transistors with a superior regulation. They achieve outstanding channel separation and a clear, powerful reproduced sound, in addition to the wide frequency response. There is a built-in surge killer circuit to suppress inrush currents from the power transformers and high currents which charge the electrolytic capacitors. This circuit ensures that none of the parts are affected by these adverse currents.
Protective Circuits Composed of Fast-response Relays and Electronic Circuits
Each channel is protected by a DC and over current detection relay circuit. In the event of the speaker terminal shorting due to poor connections or when DC current is generated in the output, the output circuit is immediately disengaged and the speakers and transistors are safeguarded against any possible damage. The protective circuits also function as muting circuits when the power switch is turned on and off.
Peak Level Meters with Outstanding Waveform Response
This power amplifier incorporates logarithmic compression peak meters with a wide scale (-40 -+3dB). With 8-ohm speakers, they allow the output to be read out from 0.01W to 300W. Moreover, the meters feature a fast response for peak signal indication. In addition to the peak output reading, it is easy to interpret the dynamic margin with respect to the SPEC-4’s clipping level.
Input Level Controls with dB Calibration
The SPEC-4 is equipped with input level controls with direct readout attenuation values (-dB). These can be used to continuously adjust the input levels for each channel in accordance with the rated output voltage of the preamplifier. In this way, the SPEC-4 can perform the proper gain control according to the preamplifier’s output level. The preamplifier will thus be used in the condition possible for the best S-N ratio and distortion characteristics.
Stylishly Professional Front Panel Design
Just as you would expect from a sophisticated system, the SPEC-4’s front panel is professionally designed with the large level meters in the center. Also. The front panel’s dimensions allow the model to be mounted in an EIA standard rack, just like real professional-use amplifiers.
SPECIFICATIONS
ICs………………………………........................................2
Transistors………………………………...........................61
Diodes……………………………….................................62
Power Amplifier
Circuitry………………………………Current mirror loaded differential Amplifier
3 stage darlington parallel push-pull
Direct-coupled OCL. (DC amplifier construction)
Continuous Power Output of 150 watts * per channel, min. RMS, at 8 ohms from 20 Hertz to 20,000 Hertz with no more than 0.01% total harmonic distortion, or 180 watts per channel at 4 ohms from 20 Hertz to 20,000 Hertz with no more than 0.03% total harmonic distortion.
Total Harmonic Distortion (20 Hertz to 20,000 Hertz, 8 ohms)
Continuous rated power output………………………………................................0.01%
75 watts per channel power output……………………………….......................... 0.01%
1 watt per channel power output……………………………….............................0.01%
Intermodulation Distortion (50 Hertz to 7,000 Hertz = 4:1, 8 ohms)
75 watts per channel power output……………………………….........................0.005%
1 watt per channel power output………………………………........................... 0.005%
Frequency Response………………………………...............5 Hertz to 100 kHertz +0/1 dB
Input (Sensitivity / impedance)……………………………............................1V/50k ohms
Output
Speaker……………………………….................................................4 ohms to 16 ohms
Damping Factor (20 Hertz to 20,000 Hertz, 8 ohms……………………………….........100
Hum and Noise (IHF, short circuited, A network………………………………........11 5dB
Miscellaneous
Power Requirements………………………………...................................AC 120V 60 Hertz
Power Consumption………………………………..........................................760 watts (UL)
Dimensions………………………………..............................480(W) x 187(H) x 445 (D)mm
18-7/8 x 7-3/8 x 17-7/16 in.
Top Acer Office Equipment & Supplies Experts
SmartAviator
SmartAviator
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
