Cars & Trucks Logo
Posted on Dec 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fault codes and how do you read them
Does anybody know or have the fault codes for a 1995 Jeep sports
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1650
Points
5
Do you need to know how to manually pull the codes?
Anonymous
Level 2:
  • Expert 100 Answers
  • Posted on Dec 28, 2009
Anonymous
Expert
Level 2:
Answers
100
Questions
0
Helped
67674
Points
282
Dear sir
good day
you can get some help here
http://www.all-parts.com/diagnostics/mechanics/Jeep-Cherokee.html
and here you'll find a list of the codes
http://www.wjjeeps.com/faultcodes.htm
thanks and GOD help you
1998 Jeep Cherokee Sport steering column won't lock into place.
website
https://big-manuals.com/products/copy-of-jeep-grand-cherokee-xj-yj-1995-workshop-service-manual
and this book helped me repair it within an hour, all by myself!!!! It's amazing, no hassle at all
From wiring diagrams, schematic illustrations, spark plugs info, parts info, stepwise instructions, torque specs, error/fault codes, engine info, to every single minute parts, you get everythingg in there you can't imagine how detailed it is
Abs not showing working on car tester, speedometer not working, check engine light on 2005 jeep liberty sport
You say the check engine light is on, if so there will be a system fault code, read that code with a OBD2 code reader
2014 jeep cherokee sport engine light comes on
engine lights also report on transmission faults
take it and have the fault codes read first to find the sensor at fault then make that decision
1995 jeep cherakee not starting
You need to run a fault code test first and also check for fuel pressure. To run the fault code test go here and read the instructions.
1993 jeep cherokee loredo wnt start
Hello
The engine and automatic transmission in this vehicles drive train are fully electronically controlled by a computer called the PCM (Power Train Control Module). Whenever a problem like this occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM
1helpful
1995 VW Jetta fault codes will not read
Hi Gregory, take the vehicle for a diagnostic scan. I am not very sure what question you're asking. I believe that you may be reporting that code 4 and 15 are reporting faults. If there are no fault codes the scanner will report 'No fault code" If it shows the two you report, a fault has occurred in those two areas. Regards John
2001 jeep Cherokee sport runs for a while and stops for 24 hours starting again like nothing hapenned
Hello
The engine and automatic transmission in this vehicles drive train are fully electronically controlled by a computer called the PCM and TCM (Power Train Control Module, Transmission Control Module). When a problem like this or other drive-ability related problems occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM
1995 jeep grand cherokee larado engine code reading 34155
Hi Angela:
We cannot understand your "345155" fault code, keep in mind that 1993-1997 codes just have two digits. I suggest re-check to read and note your fault codes acdording with this read codes procedure, with out starting the engine: turn the ignition key on, off, on, off, and finally on.
The check engine light on the dash will begin to flash. The light will flash the first number of the first digit pause and flash the number of the second digit. Example: five flashes, pause, three flashes = Code 53 PCM failure or Code 54 no cam shaft position sensor signal from distributor etc, etc.
Try this and send us this fault code to send you additional detaild.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
How do I get the FCC Code for my 1995 Jeep Grand Cherokee
Turn to ON position three times (dont start engine) and read odometer code blink lights; If the "check engine" light illuminates, it will either blink or remain constant, depending on the problem.
This and other additional details can find it in Check Engine and OBD Fault Codes articles.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
