Watches Logo
Posted on Dec 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Purchased a new pulsar chrono as a gift, the battery was dead, since found out low charge batteries are placed in new watches to check functions but they recommend the battery be change. Problem is, battery was changed, watch runs for about 5 hours then stops. If you pull out the crown and push it back the watch will run again. What do you think?
Anonymous
Level 2:
Scholar:
  • Expert 151 Answers
  • Posted on Dec 26, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
151
Questions
0
Helped
60565
Points
304
I would return it sounds not like a batt. problem but internal mechanical. If you have a reciept dont deal with a potential problem get a replacement.
1helpful
2answers
Pulsar analog/digital watch model number 130139
Clearly, it is faulty and has some type of parasitic drain. All watch batteries should last a couple of years. My Seiko last for about 3 to 4 years. Return it to Pulsar or a repair agent for repair.
Pulsar Watches - Tell it your way
https://www.pulsarwatches.com.au
Service & Repairs Service Agents Watch Care FAQs Instruction Manuals · Contact. PULSAR. Pulsar. ©2021 Seiko Australia. All Rights Reserved.
Watch Care · ‎Customer Service · ‎Abbreviations · ‎Glossary
Pulsar Watches - Contact
https://www.pulsarwatches-europe.com Pulsar burst onto the world watch scene with the first ever LED watch. Ever since, the name has been synonymous with adventurous and leading edge design.
The back of my pulsar solar watch says not battery required but it is not running, where can I take it for repair
sadly, if the battery is indeed dead, it's time for a new watch. the cost to replace the battery will be the same as buying another one off ebay, pawnshop, craigslist etc.
1helpful
My son received a new Timex Ironman 30-lap watch as a gift but the screen has always been blank and we don't know how to turn it on. Does this mean we need a new battery, even though the watch has never...
It is possible that the battery is dead even if the watch is new. The watch may have sat on the store shelf for years draining down the battery before it was purchased.
Perhaps it didn't even come with a battery installed although that would be more unusual.
Occasionally a new watch will have its battery installed, but wrapped with a plastic strip or cover over the terminals to prevent it discharging while in the store.
Either way, you will have to remove the back cover to check. You can do this yourself or you can bring it to any jewellery store and have them do it. They don't usually charge any more than $10 parts and labour to change the battery in a watch.
Here are a few Youtube videos on how to replace the battery on similar watches and a review:
http://www.youtube.com/watch?v=nNnbFUmthoY
http://www.youtube.com/watch?v=GjMClefLsA4
http://www.youtube.com/watch?v=56zcAsdh268
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the video.
Good luck, hope this helps.
2answers
Pulsar chrono hand alignment
mcdedevito75 here, Return to the watch rep[air that installed the battery for adjustmaet.
2helpful
2answers
Touch function is not working
I had the same issue. After installing the battery and trying to calibrate several times... to no avail.I tried pressing the T button, keeping it pressed down and then install the battery. It give you a mode or function setting ( I'm not sure what it means). i then press the T button and it cycles through these mode setting. I synchronized the hands and then was able to get the: altimeter, compass, meteo, date and time working. The temp, chrono still doesn't work.
I think getting all the functions to work, depends on the mode setting... but i don't know the correct setting.
1helpful
Hye...my watch swatch stop functioning even i already changed the battery.
Could be Following Reason
1, Watch movement required overhaul
2, Circuit or coil warn out
3, Battery connection are not on right place
4, Test new battery to check its strength
If watch has only battery cover on the back and does not has backcase
like most of swatch watches are then watch can not be overhaul.
hope this information is helpful
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
How do you change the battery in a calibri pocket watch ?
go to the store where u bought the watch....or any store where there sell batteries the normaly will exchange and fit it for u
Need to change the battery
Go to the watch repairing shop near by your place and get it reapired.
OR let me know your address so I can provide you the repairing center near you.
Thanks.
Mzas
5helpful
3answers
Flashing numbers in squares
Flashing Squares means battery going dead - time to replace. May take up to 3 months to stop.
Top Pulsar Watches Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Pulsar Watch Expert? Answer questions, earn points and help others
