Question about Tissot T-Touch T33759851
Touch function is not working
My t-touch is locked on the chrono function. When I touch another function, it moves but then immediately returns to the chrono function.
Posted by toddak5 on
Anonymous
    New Friend:
I had the same issue. After installing the battery and trying to calibrate several times... to no avail.I tried pressing the T button, keeping it pressed down and then install the battery. It give you a mode or function setting ( I'm not sure what it means). i then press the T button and it cycles through these mode setting. I synchronized the hands and then was able to get the: altimeter, compass, meteo, date and time working. The temp, chrono still doesn't work.
I think getting all the functions to work, depends on the mode setting... but i don't know the correct setting.
Posted on Jul 09, 2010
Anonymous
  • 3 Answers
I had the problem with locking on chrono function. Then I decide to replace battery, after replacement it becomes crazy, hands were moving all the time, it was impossible to stop it. I remove the battery and leave watches on the table for 5-6 days, then install the battery again. No problem any more, all functions are available. Good luck!
Posted on Aug 06, 2010
My Coifman sc0170 has stopped working , I've only worn it 6 or 7 times i bought it in March 2016 , after wearing the watch I always put it back in its box any I dears plz
I see that this is a quartz chrono. Firstly, make sure that the crown (winder) is fully pushed in. If you have had the chronograph function running all the time, this will deplete the battery quite quickly. Also, when you buy a watch, depending on where you bought it, it may have been running for some time perhaps as a display model so the battery might already be well used.
If pressing the crown in doesn't sort it, get the battery replaced. If that doesn't get the watch running then you should return it as faulty (as it was a very recent purchase). If battery replacement does get the watch going then you might want to read the manual to ensure that you're not constantly running the chrono function, which will seriously reduce the battery life..
Jun 05, 2016 | Watches
How to reset the chrono function of a Tag Heuer Aquaracer Calibre S CAF7113.FT8010 after a battery change
Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works..
Jan 17, 2014 | Tag Heuer Aquaracer Calibre S...
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
Feb 28, 2011 | Calvin Klein K7547107 Celerity Watch for...
I have a sport watch fossil CH2470. the second hand is not moving, stuck on 12, but everything else works. how do i fix this?
Your watch is Chronograph watch and the big centre seconds hand is for chronograph function only - not day to day seconds counting. Check the small dials and you will see that the small seconds hand is already counting seconds- this small one is seconds counter. To engage chrono hand push the upper push button once. To stop it - push the same button again. to return to zero- push lower button. For users manual use this link: http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html Rate me, please.
Feb 28, 2011 | Fossil Watches
The date and time are changing by themselves
I had the problem with locking on chrono function. Then I decide to replace battery, after replacement watches become crazy, hands were moving all the time, it was impossible to stop it. I remove the battery and leave watches on the table for 5-6 days, then install the battery again. No problem any more, all functions are available. May be you have the same kind of problem. Good luck!
Jul 02, 2010 | Tissot T-Touch T33759851
Second hand does not return to zero caliber 3606
Yes, this can be recalibrated from the outside. To get your chrono hands pointing in the right direction pull the crown out to the first position then click the plunger/ chrono button. This should move your chrono hand one click at a time to get it to the right place. If this does not work try pulling the crown out to 2nd position (all the way out) and try clicking the plunger as described above.
If this STILL does not work, which it should, then you'll need to go to an Omega dealer and have them take a look at it.
Oct 19, 2009 | Omega Seamaster 300M Auto 2531.80.00 Wrist...
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Jan 05, 2009 | Bulova Watch
Invicta Ocean Ghost Chrono Model# 2636
Did you recently have a battery changed. A lot of times on chronos when the battery is changed the battery has to be short circuited to the AC. Which is done by taking tweezers. & touching the positive part of the battery to the part of the watch marked AC. Then try to pull the crown all the way out to time setting position press the top rt button & the second should move keep moving until it lines up with zero. If you haven't had the battery changed try what I told you to do with the crown & the top right button.
Mar 13, 2008 | Invicta 2636 Ocean Ghost Chronograph Watch
Tissot T-Touch T33759851 Logo
1,198 people viewed this question
Top Tissot Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Anonymous
Level 1 Expert
Are you a Tissot Watch Expert? Answer questions, earn points and help others
