You could plug it to ac and try to play your usb or sd card mp3format. There are some rechargeable equipment that does not work while plug into ac, because the use of the ac adaptor is primarily for charging the battery. Yet like laptop, or portable dvd you can use it while it charges the battery.
Follow this procedure to troubleshoot if the power will not turn on.
Ensure you are using fresh or fully charged batteries. Check if the battery using is NPBG1 (supplied)
IMPORTANT: Batteries discharge more quickly when used in cold weather conditions.
Attempt to turn on the camera.
If the issue is not resolved, try replacing or recharging the batteries if available.
Attempt to turn on the camera in Playback/Edit mode by moving the mode switch to the Playback/Edit mode or by pressing the playback button.
Switch the unit to camera mode and attempt to turn on the camera.
If the issue is not resolved, try connecting the AC power adapter to the camera and a working electrical outlet.
(Skip this step if the camera being used does not support the use of an A/C adaptor.)
Try power resetting the Camera. (Remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the battery after 1 minute and check if the Camera works normally.)
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required.
If you're located in the U.S, online repair request can be created for getting the unit serviced at the Factory service center by clicking the link below:
https://eservice.sony.com or else by selecting your country from Sony Global webpage.
charged batteries. IMPORTANT: Batteries discharge more quickly when used in
camera.
Switch
If
camera and a working electrical outlet. NOTE: Skip this step if the camera being used does not
Attempt to turn
on the camera.
Remove the Battery, press the power button for 30 seconds.
Please wait for one minute, insert the Battery and turn it on.
The troubleshooting
of the steps and the issue is not resolved, service may be required. [[]]
The problem was being caused by the wireless USB adaptor. When I disconnected the adaptor the webcam picture came good. I plugged the adaptor into a different USB port on the machine and no interference. I don't have any explanation for why on one USB port I get the interference and on another I don't get any interference. I am happy to live with it like it is if it works.
The manual does not say that the camera must be plugged into a power adaptor. Then press the playback mode button below the lcd screen. Select PC/Printer and you will be hooked up
Sounds like a mistracking problem, probably due to loosened up guides. Camcorder should be at least partially disassembled at its front where the tape is located in order to expose those guides (they look from above like normal big screws with a kind of protuberance at the center) thru which the tape traverses before and after the head drum. Then, with a lot of patience, they must be tweaked back and forth until playback resumes fine operation (there are more professional ways to do this with electronic instruments, of course, but if you only want to play back old tapes this should be OK for household purposes). If this doesn't solve the problem, it might be a worn out / damaged video head drum, which should be replaced (a task best left to qualified professionals due to its complexity). Hope this helps. Bye and good luck !
With the Sharp Viewcam ®, there's no need to use an adaptor to play 8 mm tape. Simply connect the Viewcam ® to the TV or VCR for playback. You can even use your VCR to make a copy onto VHS tape.
