Avaya Definity 8434DX Corded Phone Logo
Posted on Dec 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The display screen on my Avaya 8434DX isn't working. Any ideas?
Anonymous
Level 2:
New Friend:
  • Expert 43 Answers
  • Posted on Dec 22, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
43
Questions
0
Helped
26876
Points
105
Check that the power brick is plugged in to a wall socket with power. The brick is gray and sits in between your phone and the phone socket. It inserts power for the display. ensure that the green LED is lit on the power brick and cables are plugged in properly. If the power brick is faulty contact your maintainer to get a replacement
How do you change the display names on the Avaya 5420.
hi robert.
see if this helps you,if not go to the link and the bottom.
How to change the display name in Avaya phone? Press the Select soft key or the OK button or the right arrow key. Use the up and down arrow keys to scroll the display to the option Display Name. Press the Change soft key to change the setting or use the left or right arrow keys. Display your extension number and the date and time on the phone when it is idle.
Display Name - Avaya
marketingtools.avaya.com/knowledgebase/user/ipoffice/.../1408/display_name.htm Search for: How to change the display name in Avaya phone?
How do you change the display names on the Avaya 5420 Google Search
Change the display name?
Administering a 1400 Series Digital Deskphone
Perform the following steps for each 1400 Series Digital Deskphone:
1. Log into the Avaya Aura Communication Manager administration interface.
2. Perform one of the following steps:
? If you are adding a new extension and want to assign a specific extension number, use
the add station nnnn command, where nnnn is the new extension you want to assign.
? If you are adding a new extension and want to assign the next available extension
number, use the add station next command.
? If you are installing the 1400 Series Digital Deskphone at an existing extension, use the
change station nnnn command, where nnnn is the existing extension you want to
modify.
The Station screen appears.
3. Perform one of the following steps:
? If you are administering a 1408 telephone, type 2410 in the Type field.
? If you are administering a 1416 telephone, type 2420 in the Type field.
4. In the Port field, type the port address.
5. In the Name field, type the name to associate with this telephone. Administering 1400 Series Digital Deskphones
20 Avaya 1400 Series Digital Deskphones Installation and Maintenance Guide
6. Configure the remaining fields on the Station screen pages. Keep in mind the following
information:
? If you are administering a 1408 telephone, the first eight call appearance/feature buttons
displayed on the Station screen are administered on the 1408 telephone. (Since the 1408
telephone is aliased as a 2410 telephone, the Station screen displays 10 call
appearance/feature buttons.) The remaining buttons displayed on the Station screen are
not administered.
? If you are administering a 1416 telephone, the first 16 call appearance/feature buttons
displayed on the Station screen are administered on the 1416 telephone. (Since the 1416
telephone is aliased as a 2420 telephone, the Station screen displays 20 call
not administered.
? If you are administering a 1416 telephone with a DBM32 Button module, the first 16 call
appearance/feature buttons displayed on the Station screen are administered on the
1416 telephone. The remaining eight call appearance/feature buttons displayed on the
Station screen are administered on the first eight buttons of the DBM32 Button module.
The 24 buttons of the EU24 expansion module displayed on the Station screen are
administered for the remaining 24 buttons of the DBM32 Button module.
For more information about administration and features, see:
- Administering Avaya Aura™ Communication Manager, Document Number 03-300509
- Avaya Aura™ Communication Manager Feature Description and Implementation,
Document Number 555-245-205
- Avaya Aura™ Communication Manager Screen Reference, Document Number
03-602878
7. When finished administering this extension, save your changes.
Online Virus Removal 39 99 Online Virus Removal and Online PC Help
I have 4 avaya 8434dx phone what else do I need to set up my phone system
You will need the Definity control unit, with the appropriate licensing
I can't get the time to stay displayed on the screen. I hit the menu button, then the TmDay button, then exit, but both the time and date disappear. I want the time to stay displayed.
Its on a toggle switch. So hit menu, select time and day, do not hit exit, wait.
If it goes away, you just shut it off do this again, and it should stay on.
Avaya IPO 406 v2. 4622SW IP phones. Ocasionally, the IP phones will get into a mode where they stutter. The stuttering affects the voice communication by interrupting the voice stream every second or...
Various potential network problems might be causing the problem. Access the Network Audio Quality screen. In the event you experience poor audio quality during a call, the problem is likely with your network. This screen provides information that can help identify causes of poor audio quality. Note: Note: The Network Audio Quality button displays only when you are on a call (off-hook). 1. Select Network Audio Quality from the Options Main screen (accessed by pressing the phone's Option button). If administered, the Audio Status screen displays. 2. To return to the first Options Main screen, press the Return softkey.
1helpful
The display went out on my AT&T 84354dx. What do I do to get it back?
Hi Check the power brick in between the phone and the wall socket for your phone connection. The brick provides power to the display. make sure there is power green LED should be lit and the cables should be plugged in properly
2answers
Change time on the phone set
Your system Admin will need to do this on their phone or via command line interface.
18helpful
Avaya 8434DX Display won't show date and time as normal display
You should be able to hit the Menu button, then the arrow directly below the TmDay display and then hit exit once the date and time are displayed. The date should disappear but the time should stay.
HOW DO YOU SET THE TIME
The time on the phone system has been reset, but you must refresh your system.
1. Press menu button
2. Press the time/day button, which displays current time & day--wait for it to time out (in other words, the screen clears and returns to menu).
3. Press exit.
Repeat steps 2 & 3 to display your clock and check time.
THIS REFRESHES YOUR CLOCK TO THE ACCURATE, CELL-TOWER TIME.
Top Avaya Lands Phones Experts
NOEL
NOEL
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
