Hello alsupjonatha,
There could multiple things wrong, and hopefully nothing serious. Here is a complete list of some problems and solutions that can be wrong with the analog stick.
1. The Left analog stick may be sticky. If you eat greasy foods while playing your Xbox 360 console, try to avoid this from now on. Grease from food particles may slip into the analog stick, and make it sticky, causing the analog to move constantly to one fixed position. Please look at the next problem and solution ahead before attempting to remove your controller with a screwdriver. Here is a complete guide on how to access the inside of an Xbox controller.
http://www.ehow.com/how_5410334_fix-xbox-controller.html
2. There may be a simple glitch in configuration. Try turning off your Xbox 360 controller by holding the Xbox Guide button for approx 4 seconds untill a menu comes up. Select "Turn off controller". After doing so, try turning on your controller again. If the problem persists, there may be a greasy analog stick, or an object that broke that holds the analog stick together. Go back to problem/soltution #1.
When they're all dead, do as Kota says and use your Force Grip. The camera will shift and two images representing your analog sticks will appear on the screen. Hold the left stick in the direction indicated. This will start turning the Star Destroyer's pointy nose to face you. This is one of the goals. The other goals are to tilt the nose upward or downward with the right analog stick. This part is pretty twitchy, so pay attention to with direction the game wants you to put it in. Also, be aware that the directions for the right analog stick are UP and NEUTRAL, not UP and DOWN. Once the Star Destroyer's nose is pointing the right way, the lights behind the sticks will turn green and it'll tell you to push the sticks up and then pull them both downward. Do it and HOLD them both down. Do not push them back up, despite what the image shows. Keep them hold down until the Ties get close and begin firing on you. Then let go and kill them again.
