Casio fx-300ES Calculator Logo
Posted on Dec 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to get it out of Sci math - Casio fx-300ES Calculator
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Dec 06, 2009
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4675852
Points
21596
To get out of the default MthIO press [SHIFT][MODE][2:LineIO]
To get out of Sci display format, press [SHIFT][MODE][6:Fix] followed by a number between 0 and 9, that will set the number of decimal digits.
Hope it helps.
Thank you for rating this solution.
Adaka Emmanuel
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 09, 2016
Adaka Emmanuel
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3123
Points
Write your answer...it is remains fix
1helpful
HOW CAN I SOLVE FIXSCI?
Both FIX and SCI are lit? What happens if you press SHIFT MODE then select either SCI or FIX?
1helpful
I want to solve FIXSCI. How can i solve it?
Both FIX and SCI are lit? What happens if you press SHIFT MODE then select either FIX or SCI?
2answers
I want it to return to the 0 level it's 0.000000000
Press the setup key (to do this press 2nd F and then MATH). Now press 1 for FSE and select NORM1 by pressing 3. Your calculator should go back to normal. Alternatively, reset the calculator by pressing the reset button on the back of the calculator.
I am not sure what my calculator is doing I am trying to solve a regular math problem such as (.0011)(2.4) and it keeps giving me 2.64 x 10 to the -03 power
You have your calculator set to give your answer in scientific notation. If you would like it to give your answer in decimal form you need to change the settings. On my calculator which is an older version, you just press [mode] three times. On your screen you will see fix sci and norm as well as the numerals 1, 2 and 3. press [3] on your key pad. You should see norm 1~2? then press [2] on your keypad and this will have changed your settings back to plain decimals.
I hope this helps!
Ashley
How do i get it out of SCI math?
Press [SHIFT][MODE] to enter (SETUP)
Enter the item number in list that corresponds to Norm or FIX.
You may have to supply the number of digits to keep in the decimal part of a result (a number between 0 and 9)
3helpful
I need to fix my calculator back
You must have changed the number display format from Fixed to Scientific. To get back to the Fixed format you press [Shift][Mode][6:Fix]. You will be prompted to enter a number between 0 and 9.
If you choose 0, all your results will be rounded. If you choose 9, all your results will have 9 decimal digits, and that can be bothersome, because you do not need all this precision.
So, choose a reasonable number (2 or 3) and all results will have 2 or 3 decimal digits.
Good Luck on you exam.
Hope it helps.
Thank you for using FixYa!
1helpful
Casion Fx-300MS
If I understand correctly you result do not display any decimal.
If you want a fixed number of decimal digits (exemple 2) Press the [MODE] key a number of times until you reach the screen that displays Fix Sci Nom and under them the numbers 1 2 3
Press 1 to choose Fixed format followed by 2 for TWO Digits
3 decimal digits [MODE] ---------[1 ] (Fix) 3
Hope it helps.
2answers
Problem withi scientific calculator
How do I get rid of the word "Fix" from the calculator display.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
