Hi
I'm sorry you can not use the program with your old computer, the requirements are.
- Intel® Pentium® 4 or AMD Athlon® dual-core processor, 1.6 GHz or higher with SSE2 technology
- 2 GB RAM
If your processor does not have SSe2 technology support, it is too old to run the program, buy a new machine. Or use a older version of autocad. your computer must be around 5 or 10 years old or more. SSE2 has been around since 2003.
Quote http://autodesk.blogs.com/between_the_lines/2009/03/sse2-cpu-support-requirement-for-autocad-2010.html
23 March 2009
SSE2 CPU Support Requirement for AutoCAD 2010
I will try to not geek out and confuse you on this post. With
AutoCAD 2010 there is an
AutoCAD 2010 System Requirement to have a
CPU (essentially the computer’s brain) with
SSE2 support. SSE2 is an
Intel
CPU instruction set (SIMD Extension 2) which is essentially technology
to replace the old MMX extensions which are half as slow in many data
and math operations.
Most current systems will support SSE2 except an old
AMD CPU system over 6 years old. AMD Opteron, Athlon 64 both support SSE2 and have since 2003.
So why SSE2 requirement in AutoCAD 2010: In
developing software there is a limit on how old of technology you can
effectively support without impacting current hardware and software
users. In the case of AutoCAD 2010 adding the SSE2 requirement this
increases performance for customers using current hardware. Many areas
improve in AutoCAD such as OSNAPs.
I said I would not geek
out so I will not go into details on floats, floating point, and
registers. Your experience may vary but the change was made for some
performance benefit of current hardware.
Bottom Line: Increasing performance is a good thing!End Quote.
