20 Most Recent
Zerus Intel Desktop Board D815EEA (Z-D815EEA) Motherboard Questions & Answers
Hello .i want know where
ftp://download.intel.com/support/motherboards/desktop/d815eea/a1696401.pdf
If you do not have pdf viewing capabilities, your browser will prompt you to install the plugin, please allow this install once you've followed the above link. In the pdf document, refer to table 48, on page 71 for how to connect your front panel.
Slow booting
check your start up files what gets preloaded get software like reg cure it will show what is been loaded on sartup
GPA Card for D815EEA
Something like this
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5699698&CatId=318
Everything better will be held back by your pc.
I need the order for placing wires black in place.
The wire placement is usually written small right on the motherboard. Each front panel connector should be labeled.
Here is the owner's manual for the motherboard:
http://download.intel.com/support/motherboards/desktop/d815eea/EA_ENGLISH.PDF
(Hint: Copy the whole link to notepad, make it all one long sentence, copy again and past into your browser)
Unable to find the power switch to connect to
If you no longer have the manual for you're Intel D815EEA motherboard, open the link provided and download it; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17793&ProdId=385&lang=eng
You will also need Adobe reader installed to view the manual; http://www.adobe.com/products/reader/
Read over pages 65 to 68.
Once completed turn to page 68 Figure 23. Front Panel connectors. Figure 23 shows two views.
View - (left figure), shows J9C1 as you look down at the front panel pins. The right figure will not be needed. Connect each jumper or each pair as shown.
Wire colors are important and do vary from case to case. The common color of each pair will most likely be used for negative. Wire colors such as blue, light blue, green, light green, red and light red are commonly used as positive.
Pin 1 will be positive and pin 3 will be negative. This is letter - C. Hard drive activity LED.
Pin 2 is positive and pin 4 is negative. Case power LED, and so forth.
As mentioned on page 65, the case front panel pins use 5 volts DC. If you make a mistake and place a jumper backwards (No LED light), just power off the switch on the back of the power supply and correct the jumper by turning it 180 deg. If you’re case’s LEDs do not light up than you will need to connect letter G and letter H. The electronic circuits under the motherboard should supply all 16 motherboard pins with the 5 volt DC and ground needed.
Cheers'
Mike
Re-reset botton pw- power botton
from the 1 pin that is single without pair..disregard that then put the pw button.. to make sure short it using a philips or long nose.. if you find the power on button...or just find first the power button by shorting the pins...
the sequnce are pw button reset button pw led hdd led..you just nid to align them to the power button..
hope i've help you..
rate...
Intel D815EEA desktop motherboard has power,
Why you should take out all the DIMMS? Taking it out will not power on your computer. Memory card or DIMM(Dual Inline Memory Module) is essential for the motherboard to operate properly or else it will not function and make your monitor comes with no display. You should insert it back from the memory slot to make your computer operational.
I hope this information could help you..:-) Thanks..
System is booting but display is not comming
u cannot use linux and xp in single system.....because linux boot loader is highier version so it will not allow the win xp boot...u need to format the system and install the xp itself..thanks
