F10 is a pressure switch fault which could just be the pressure chamber is blocked and needs cleaning out
use this link for error code Domestic Appliance Help
code showing h20 is the clue water is also known as h20,so your problem is the inlet valve letting the water into the back of your machine needs replaced or water pipe is kinked and no water is at the supply,. these valves are cheap at 10 dollars,adrian.....
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Get unit to spin and drain. See if any of those are a problem. Check if heating element has a circuit and if possibly an over temp cut out has occured. Normally if a code no. has come up, a certain condition has occured which should be rectified.
I have the solution for your query.
In your browser bar, type in ----
indesit user manuals
Click on---
manuals- user guides- handbooks- indesit service
In the search box enter your model and down load the relavent instructions.
Please leave a fixya rating if you consider my solution appropiate to your problem.
Thankyou.
