Describe your panasonic kx-fhd331 reprint fax Problem. Paper jammed during receipt, but I could hear the fax machine still "printing" on nothing. Is there a way to reprint the fax or is it gone from memory?
If you run out of ink, paper, or the machine jams the fax will be stored in memory. After these conditions are cleared the "stored fax" will print and automatically clear from memory.
I have a problem with the fax machine in question is panasonic kx ft77 . When receiving a fax error expel warm up and stop receiving the document. Or does anyone know what the problem is and how to fix it ? Thanks in advance
Make sure there is no additional error messages on the screen - they usually show in a sequence one after another - maybe paper not loaded correctly,or machine is jammed or out of thermal film.
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
