Alpine CDA-9883 CD Player Logo
Posted on Oct 27, 2009
I have an alpine cda-9883 cd won't eject & error
I have an alpine cda-9883 and inserted a cd. It played the first 2 songs and then showed nothing for the rest. When I tried to eject it would not and I got an error. Cd will not eject.
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Dec 15, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
Helped
5243
Points
26
Try detaching the "face" and there should be a little button that you can only push in with some kid of really thin stick,maybe a pin that will reset the cd player and hopefully work
Play 3 cd tracks
make sure your cd player is clean.
Cda 9883 - no sound
Check for blown fuses behind the deck and under the hood, sometimes by the battery, you may get lucky but you could have smoked the unit, and would not know anything unless you send it in to get fixed. Replacing the unit could be the answer Alpine CDA-9883 CD Player
2helpful
No power to my alpine 9883
Check for a fuse in the back of the radio, and the one in the fuse panel
Alpine cda- 9883 radio will not recognize ipod
your ipod might be too new,and your cd player too old the alpine cda 9883 is a 2007 model what kind of ipod do you have,if uyou have an older ipod and got the new itunes9 then try downloading an older version of itunes from itunes.com .....good luck
2helpful
2answers
Stuck cd
press & hold the eject button
How to turn mx on the alpine cda-9883
press and hold the menu button until display changes then turnthe the volume button until mx shows in the display then press the tuner button to turn on that feature
1helpful
Radio has sound but not the CD player or iPod
Your amp is not turning on - what you should do is connect the "blue/white - remote turn-on lead" to whatever wire you have the "blue - power antenna" output from the Alpine connected to now. That should solve your problem.
Cda 9883 and cda 9885 2008 model no song issues
My ipods fuction fine with my Alpine CDA-9885 ... have you tried pressing the display button on the Alpine? The KCE-422i cable takes quite a beating ... You might check the cables.
1helpful
Cd plays, but no sound
Disconnect the blue wire from the back of the radio and connect the blue/white wire in its place. This should fix your problem.
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
