Cda 9883 - live power wire from battery touched an rca cable then I heard a loud pop sound, smoke came from the deck and now I get no sound all from any channels.
Check for blown fuses behind the deck and under the hood, sometimes by the battery, you may get lucky but you could have smoked the unit, and would not know anything unless you send it in to get fixed. Replacing the unit could be the answer Alpine CDA-9883 CD Player
It seems that is bad grounding of the gear, check i everything is conected to ground. I can also be the quality of the cable, Bad cables can produce a lot of noise, try using other cables.
whay type of vehicle are you putting the cd deck in ? if it has a factory amp , it may have one amp per speaker , get the specs on the new vehicle to find out . using a "free harness" is always a good idea as well , it plugs directly into youre vehicles factory radio harness and has labeled wires coming off the end so u know whats what there .
your ipod might be too new,and your cd player too old the alpine cda 9883 is a 2007 model what kind of ipod do you have,if uyou have an older ipod and got the new itunes9 then try downloading an older version of itunes from itunes.com .....good luck
Ckech the ground, the only thing i can think is that the amp is trying to use them as a ground... but you probably have an extremely fried amp and guts are melted and making your RCAs make contact with the power wire, so i'd be real careful, and probably trash the amp. sorry about your luck dude...
Check the face plate pins and the deck side for build up, you can scrape them w/fingernails to clean any excess dirt etc. off them, then replace the face. That's about all you can do. If the faceplate LCD is bad you can by a new one, generally 150-200 for a new face. Check with an Alpine dealer, most good custom shops are actually very helpful.Best of luck
Your amp is not turning on - what you should do is connect the "blue/white - remote turn-on lead" to whatever wire you have the "blue - power antenna" output from the Alpine connected to now. That should solve your problem.
are you using RCA outputs(the round red and white plugs)? if you are then your amp is not turning on and if you are hooking up speakers to your RCA's (low level) then you will not hear any audio the signal is to low. would need to know more about how you checked the ic power?? one could verify an output ic by hooking up an amp since the RCA audio signal is picked off just before the output. if the low level works but the speakers do not then you have a bad output. anything else an o-scope would be handy.
good luch stereo tech ([email protected])
restoring factory settings won't revert the player back to previous ipod software. Check with the alpine website product support and see which ipod software versions are compatible with the car deck you installed.
I would think the latest version would be supported. then go to the apple website and download the most recent version of itunes that alpine says is compatible. connect your pod and open itunes. upgrade the pod to that itunes version and try it again with the car deck.
you would need rca cables, power wire, ground wire, and remote wire. it is easiest to just go to your local best buy or circuit city stores and buy the whole set in one package. rca's lead from your decks rca output jacks to your amp, remote wire leads from your decks wiring (blue remote wire that leads to your deck itself to give it remote) or any 12 volt source like where your fuses are located and it runs to the amp also, your power wire will lead from your battery to your amp, and your ground will need a good place somewhere in your car and be bolted or screwed to the frame of your car. this is how to intall your deck to your amp. i assume that you already know that wires will have to be under your carpet or kickboards and such however you run them. i think this covers the basics and i hope i have answered your question right, good luck
