Remove the lamp door on the bottom, remove the lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
if it was working before lamp replaced "replace lamp" appeared on the screen either lamp somehow not in correctly, new lamp bad, or something happened during lamp installation--have you tried to put the old lamp back?
Hello * Turn the projector ON, and press the MENU button to display the on-screen Menu. Select the 'setting' menu with point UP/DN button. Press '>' button to acess sub menu items. * Select the Lamp Counter reset and press the OK or '>' button. "Lamp replacement counter reset?" will appear. Select "Yes" and then press OK or ">" button 8 Another confirmation dialogue box appears, and select "Yes" to reset lamp replacement counte.
** Do not reset the lamp replacement counter without implementing lamp replacement. Be sure to reset the lamp replacement counter only after replacing the lamp.
Callout
Component Name Notice: Refer to Fastener Notice in the Preface section. Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Turn Signal/Stop Lamp Assembly Replacement - Rear
Nut, Turn Signal/Tail Lamp (Qty: 3) Tip Pull back rear compartment carpet to gain access to lamp. Tighten 2 N·m (18 lb in)
Lamp, Turn Signal/Tail Lamp Tip Twist the bulb socket and pull inward to replace the bulb.
License Lamp Replacement
Screws, License Lamp (Qty: 2) Tighten 2 N·m (18 lb in)
Lamp, License Lamp Tip Twist the bulb socket and pull inward to replace the bulb.
Hello
To replace lamp in JVC projection TV follow the steps below. [1].Order a compatible replacement lamp from JVC. Order a replacement lamp from JVC's Accessory Store or a local authorized parts distributor to ensure that you obtain a compatible replacement lamp. To order a replacement lamp, you must have the lamp type and lamp code of your JVC projection TV, which can be found on the rear of the television. [2].Turn off the television and allow the bulb to cool. For safety reasons, turn off and unplug your television before accessing any of its internal components. Wait at least 20 minutes before attempting to replace the lamp so that it has time to cool down. If the back of the television is not warm or hot to the touch, it is safe to begin removing the lamp [3].Unscrew and remove the lamp door. The lamp door on JVC projection TVs is located on the rear left of the television and is shaped like a square. Several warnings related to the lamp will be printed on the door. Use a Phillips-head or flathead screwdriver to remove the large screw, then remove the door [4].Unscrew and remove the lamp assembly unit. After you have removed the lamp door, you will see the lamp assembly unit. Use a Phillips-head screwdriver to remove the two screws. One screw is on the top right corner of the unit and the second screw is on the bottom left corner of the unit. Detach the lamp assembly unit from the compartment by lifting the handle and pulling the unit away from the television [5].Install the replacement lamp and secure the lamp door. Hold the replacement lamp assembly unit by the handle and insert it straight into the compartment. Reinsert and tighten the two screws onto the lamp assembly unit with a screwdriver. Place the lamp door back onto the television and tighten the screw to secure it to the television [6].Reset the television's lamp timer. Press "Menu" on the television's remote, then scroll to and select "Lamp Timer Reset." Press "OK" to rest the timer. A prompt will appear notifying you that the timer has successfully been reset
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available.
Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good.
To buy original lamp.Click this link directly:---
http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/Optoma+Technology+Inc/Optoma/BLFS300B/New.aspx
this is link for compatible cheaper lamp.Click this link:--
http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx---------------
The procedure to replace the lamp:--- to get this procedure.Please click on the link below:---
this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Lamp Replace Counter Be sure to reset the lamp replace counter after Lamp Assembly is replaced. When the lamp replace counter is reset, the LAMP REPLACE Indicator stops lighting. Note : Do not reset the Lamp Replace Counter until after the projection lamp is replaced. 1. Turn projector on, press MENU button to display the On-Screen Menu. Press Point left or right button(s) to move the red frame pointer to the Setting Menu icon. 2. Press Point down button to move the red frame pointer to "Lamp counter reset" and then press SET button. The message " Lamp replace counter reset? " is displayed. Move the pointer to [Yes] and then press SET button. 3. Another confirmation dialog box appears and select [Yes] to reset the lamp replace counter. Note : Do not reset the Lamp Replace Counter until after the projection lamp is replaced. This projector uses a high-pressure lamp which must be handled carefully and properly. Improper handling may result in accidents, injury, or create a fire hazard. Lamp life may differ from lamp to lamp and according to the environment of use. There is no guarantee of the same lifetime for each lamp. Some lamps may fail or terminate their life in a shorter period of time than other similar lamps. If the projector indicates that the lamp should be replaced, i.e., if the LAMP REPLACE INDICATOR lights up, replace the lamp with a new one IMMEDIATELY after the projector has cooled down. ( Follow carefully the instructions in the LAMP REPLACEMENT section of this manual. ) Continuous use of the lamp with the LAMP REPLACE INDICATOR lighted may increase the risk of lamp explosion. A Lamp may explode as a result of vibration, shock or degradation as a result of hours of use as its lifetime draws to an end. Risk of explosion may differ according to the environment or conditions in which the projector and lamp are being used. IF A LAMP EXPLODES, THE FOLLOWING SAFETY PRECAUTIONS SHOULD BE TAKEN. If a lamp explodes, disconnect the projector's AC plug from the AC outlet immediately. Contact an authorized service station for a checkup of the unit and replacement of the lamp. Additionally, check carefully to ensure that there are no broken shards or pieces of glass around the projector or coming out from the cooling air circulation holes. Any broken shards found should be cleaned up carefully. No one should check the inside of the projector except those who are authorized trained technicians and who are familiar with projector service. Inappropriate attempts to service the unit by anyone, especially those who are not appropriately trained to do so, may result in an accident or injury caused by pieces of broken glass.
The replacement lamp must be of the same code number and type with the old one.(Samsung BP96-01472A Lamp)
The lamp type is indicated on the right side of the TV. It is also indicated on the lamp case.
You can search online where to buy replacement lamp.
Caution:
Replace the lamp with the correct lamp type to avoid damage to the TV.
Turn off the TV and wait for 30 minutes before replacing the lamp to allow it to cool
Do not touch the glass part of the lamp with your bare hands nor insert any foreign object inside the cover as it may cause poor screen quality, electric shock or fire.
Do not place the old lamp near flammable objects or within the reach of children.
Tools needed:
Phillips screwdriver and a pair of gloves.
Procedure:
Remove the 4 screws securing the lamp cover.
Remove the lamp cover.
Remove the screw securing the Lamp by using a screwdriver.
Separate the Lamp from the engine by holding the handle and pulling it out.
Reinstall the Lamp by following these steps in reverse order.
Align the lamp cover with the groove and secure the screws. The TV will not turn on if the lamp cover is not correctly closed.
Speciality Lamp Shades
Add a finishing touch to your shades. Reverse Painted & Dome Glass Shades ...ReplacementGlassLamp Shades- Reproduction & Custom ...www.specialtylampshades.com/lampshades.html - Cached
Touch & Glow Replacement Kit | LampsPlus.com
3-way touchlamp. Saves energy. Extend bulb life. ...Glass Shades. Light Bulbs. Night Lights. Under Cabinet. View All Categories. Bathroom Lighting ...lampsplus.com/.../Touch-and-Glow-Replacement-Kit__35098.html - 110k - Cached
Elegant Touch: Brown's Lampshades... a special accent for your special lamp and replacementlamp shades. ...Glass Small Tear Drop Lamp Finial. c3-finial $12.95. Crystal Gothic Cross Lamp Finial ...brownslampshades.com/store/ctgy/elegant-touch.html - Cached
Replacement Shade for 2198 Floor Lamp - Shop.com
Shop for Replacement Shade for 2198 Floor Lamp and Floor Lamps at Shop.com. the 2198TA lamp was designed by fontana arte in 1954. a very dignified modern touch to an...shop.com/replacement_shade_for_2198_floor_lamp-59830151-7...
