I know the circuit diagram for two way switching, but how do you physically wire the circuit. Do you need three core cable?
Many thanks.
Andrew
If the power originates at the location of the light (or other item being switched) you need a 3-core cable from there to to each switch location.
If the power originates at one of the switch locations you need a 2-core cable from there to the fixture and a 3-core cable to the other switch location. (If the cable to the second switch location is routed through the junction box at the fixture then you only need 4 cores from the first switch to the junction box--three switch wires and the neutral wire for the fixture.)
In all cases described above the ground (earth) wire is separate and not included in the count.
