1. Verify if your pc passes the system requirements. (a) usb 2.0 port (b) You are running the latest version of itunes
2. Recharge your iPod Touch
3. Check USB connections. Use a USB port that is built into the computer instead of using an external usb hub.
4. Restart iPod Touch. Do the following steps:
To restart iPod touch, first turn iPod touch off by
pressing and holding the Sleep/Wake button until a red slider appears.
Slide your finger across the slider and iPod touch will turn off after a
few moments.
Next, turn iPod touch on by pressing and holding the Sleep/Wake button until the Apple logo appears. Is iPod touch not responding? To reset iPod touch, press and hold the
Sleep/Wake button and the Home button at the same time for at least 10
seconds, until the Apple logo appears.
5. Restart your computer then reconnect your iPod Touch
6. Try reinstalling iTunes. And if this doesn't resolve the issue, you can also try uninstalling iTunes then reinstalling the latest version.
7. Check if there are third-party software that might prevent iTunes from recognizing your iPod touch. Such software may be security software, anti-virus software and webcam drivers. What you can do is adjust the software settings or you may also temporarily disable the software.
If you find this helpful, kindly click the thumbs up button. Thanks! :)
1. Reset or restore your iPod for a try, this can fix many general iPod problems.
2. You may try this iTunes alternative, I always use it to upload music and video to my iPod once my iTunes can't recognize my iPod, my friends recommend it to me, it's safe and works pretty well, you can also use it to copy music and video from ipod to computer for backup, it's useful when you lost your iTunes library.
3. Update your iTunes to the latest version. Plug in your iPod. If iTunes can't recognize it, then in iTunes in the top left corner click help> run diagnostics. On the box that comes up, check the last two things. Click next and it should identify your iPod. I got this method from Apple technical support. Hope it helps. Contact me if you have any other question.
1. First, Open up iTunes, plug in your iPod Touch/iPhone to the CPU's USB port. Turn on your CPU's speaker and make sure it is loud enough that you can hear it.
2. Hold down the Home button (top left for iPod Touch and top right for the iPhone with the screen facing you) and the Power button (located on the front bottom of your iPod Touch/iPhone) simutaneously, until the screen goes black and the device turns off. (past the red slider/slide to power off screen)
3. Now let go of the Power button, but continue to hold the Home button. Your iPod Touch/iPhone should have turned off and the screen should not be on.
4. After around ~10-20 seconds, you will hear a noise (beep/ding) from your CPU as if it had just recognized a new hardware device, now iTunes should recognize it in DFU mode.
5. After iTunes recognizes the iPod Touch/iPhone, let go of the Home button otherwise it will go into recovery mode and you will have to do the entire DFU process over again.
6. You will know when you have put your iPod Touch/iPhone correctly into DFU mode when the display is blank and that you do not have anything on your device. 7. Restore ipod using itunes
I second that solution marynelson37 gave you. What kind of question is that anyways? Do what the ipod says. Open up itunes and then hook the sync cord up to your computer and ipod.
try holding the home and sleep/power buttons
if not...
hold the home button and plug it into your computer and continue to hold
if not...
plug in to the computer then wait until you see the apple logo hold both buttons until the screen is blank then release them. hold them both again until the apple logo appears then continue to hold them until it goes away. release the sleep/power button then hold the home button until it appears in itunes
next time jailbreak using blackra1n it is a lot easier
Try resetting it while it is connected.
Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
If you have not already tried, I would also try the other ports on the computer.
try to hold the home and power button for 10 seconds and then release the power button without release the home button wait 9 seconds the a window would pop up saying the u needto restore ur ipod touch do it and the is going to solve ur problem and if it doesnt let me know.
