Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
Posted on Oct 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kp-57wv600 glass anti glare gone can it be reglazed or repaired or replaced
Anonymous
Level 3:
Top Expert:
  • Sony Master 14,553 Answers
  • Posted on Oct 17, 2009
Anonymous
Sony Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718815
Points
48227
If you are talking about the outer screen, it is available----part number is:
4-088-638-01
It is about 142 dollars--this set actually has three screens, this is the outer one--the inner two are MORE expensive--usually you have to remove all three to replace any of them--I can tell you the site that does sell this part--you need to be sure which screen you want--They are the largest OEM parts dealer in the world---Located in the Los Angeles area of California--allow for the fact if not for resale they will get you for sales tax and SHIPPING---
If the outer screen got a scratch or cleaned with the wrong thing it is possible to remove it and just use the other two screens--yes you will have glare if it is not there--the inner two screens deal with picture-if either of them is damaged you have real problems--
Usually someone cleans the outer screen with something that streaks or discolors it--hard to watch once it is there and almost impossible to clean streaks away.
Let me know if you want to know the place in California that sells this--they can tell you actual cost with shipping etc.
Regards, SD TECH
KP-57WV600 red led blinks 5 times
Power supply regulator section has the fault. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center. If you wish to get more details about these kinds of fault, check this link.
Rear Projection HDTV-Ready Television and help with Sony KP-57WV600 57 in. ... still have sound, does this mean the projection lamp gone bad? When you turn on the TV, you can see a unclear image for few...
with this type of tv, you can be almost certain that something has gone wrong with the lamp or the cooling system for the lamp. the cost associated with these kinds of fixes are usually more than the unit is worth. The life span on rear projection TV's is not all that good,5-10 years. some last longer. but for most this is a good estimate. this tv has an auto focus feature that might help. also if this TV has a SD slot for upgrades, give it a try as well.
15helpful
2answers
How can you clean the glass on a Canon 8600F
Got this from Canon.com: The foggy haze on the glass is actually an anti-glare treatment that has been intentionally applied to the underside of the scanner glass. This treatment lessens the glare from the lamp under the glass and provides better image quality. This haze may not appear uniform because of the shape of the scanner base and the components under the glass. However, the anti-glare treatment has been uniformly applied and the haze is as expected.
1helpful
Sony Projection TV problem
sony rear projection KP series are know for having bad utbes after while..ihad seen the blue tube goes on most.
3helpful
Fog build up on underside of glass plate.
I made contact with cannon and received this reply. I was satisfied with the answer but the question still remained on how to remove the glass should i wish to do so. Also after there answer... would there then be a problem if i did clean the reverse side. Their answer was initialy this...
expected.  The treatment should not affect the scan quality or output of
the 8600F.
Sony kp-57wv600
hola al problema lo debes tener en los transistores de color que estan en en la plaqueta donde va el socalo debes tener alguno desoldado
2answers
Sony KP-57WV600
· 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
2answers
Sony KP 57WV600
how many times does it blink?
1helpful
How do I remove the outer protective screen on my Mitsubishi WS-55315?
There are trim pieces around the edges that can be removed by sliding a knife underneath and lightly prying. They should remove fairly easily, don't force them as they may break. Use the knife on the cabinet side and pry toward the center of the screen.
The tear on the inner screen may be best left as is.
lexan would be better than plexi as it is tougher, but try to get anti-glare if possible. Anti-glare plexi would be better than regular lexan.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
