SOURCE: How to replace battery pack for a Norelco 6885xl electric shaver
The battery pack is soldered to the shaver's circuit board. Yes, it's a poor design in building something that people can't readily service unless they have a soldering gun, ******, and wick, plus patience. However, there are plenty complaints online already, and my shaver won't get fixed by b-tching some more.
There are 2 choices for replacement:
1. Bring or mail it to a service center to have the batteries replaced. The fee usually runs $29.99-$39.99, which includes the battery, parts, labor, lubrating your motor, cleaning the interior, cleaning/stripping the cutters, heads, and trimmer, plus return shipping.
2. To save yourself $26-33 bucks, make sure you know how to solder and have the equipment described above. you can find single NiCad AA with solder tab for $3ea or a pair for about $7.95+. Table the batteries together, solder a single tab across +/- on one side, and solder the others onto their respective tabs in your shaver.
For me, I'd love nothing than to hobby around and do it myself, but with 3 kids, a full-time, job, Wii, and other hobbies, it's easiest to just send it out... some services will guarantee to have it done within 2 days of receipt. You'll just have a lil beard to test it out when you get it back. :-)
SOURCE: how to replace battery on braun 7526 electric shaver
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Install new circuit board and reassemble
SOURCE: Electric Shaver will not charge
There are 4 small philips head screws deeply recessed on the rear of the razor. Unscrew these and the back half of the case just lifts off. Unsolder the battery leads and fit new battery pack.
SOURCE: I lost my Philips Coolskin 7775X shaver charger.
Hi, You can purchase a new charging cord from electricshaver.com for around $23.00 which is probably the best thing to do if you want to keep using the shaver.
Otherwise the specs for the shaver are as follows:
The part number for the replacement charging adpater cord is #3605160
Here's a link to the part you're looking for, should you decide to purchase a replacement instead of trying to make your own charger, which will be difficult unless you have the full array of electrical components and ability to fabricate it.
http://www.electricshaverstore.com/get_list_144.htm
You can also give them a call at 1-888-476-1785
Hope you find this Very Helpful and best regards!
SOURCE: I own a Braun Electric Shaver Model 6525 Flex
if the shaver is DEAD and the green light no longer illuminates when you plug it in, the circuit board is almost certainly bad. The circuit board will burn out if you run the shaver from the batteries for a long time after the batteries have stopped charing properly.
you can purchase a new circuit board which has the batteries alrady on it. it just needs to be dropped in place inside the shaver.
you will find this part at shaveroutlet.com. see link below
http://shaveroutlet.com/braun-printed-circuit-board-with-batteries-p-107.html
Are you missing the entire base as well or has the plug-in adaptor just failed?
If it is the latter, about any technician with a soldering iron can do a little surgery and replace the 'wall wart' if that is what has failed.
