20 Most Recent
Philips 7140XL Electric Shaver Questions & Answers
1.5 year old 7140XL worked fine, then next time
There are two likely possibilities. These problems would either be that the head is damaged or jammed or there is a loose connection inside.
You can easily test if it is the heads by flipping up the head assembly and then turn it on. If it runs with the heads flipped up but not when they are snapped down, you can assume that the heads are the problem and they will need to be replaced. You will find replacements for this model at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
If the shaver will not run with the head flipped up either, you may have a loose connection inside...usually from the moto to the circuit board or from the battery to the circuit board. You may be able to locate and repair this but if your shaver is 1.5 year old, it is still under warranty. If this is the case, contact Norelco using the info in your user manual for the warranty
My charger won't work
All I can say is that you'd better buy a new one cause 7 years it's more then better
Blade for Philips HR1115
https://www.google.com/search?q=Blade+for+Philips+HR1115&oq=Blade+for+Philips+HR1115&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
Philips sonicare toothbrush turns itself on
Its haunted. you need a priest to bless it with holy water.
Or the button is stuck with toothpaste. Mine did that and the battery ended up failing a few weeks later. New ones are lot cheaper than when I bought my first sonicare.
