Jack Lalanne Power Juicer 250 Watts Logo
Posted on Oct 09, 2009
I want to take it apart to clean it. How do I
I want to take it apart to clean it. How do I take it apart?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
470
Points
You remove the top and back end. (you will need to put the silver handle down to do this) You then need the crescent tool to unhook the blade. After the blade comes out, the strainer and top level will come off with no further problem.
If for some reason you do not have the crescent tool, if there is someone to hold the strainer still, you can use two screwdrivers in the holes of the blade and press down and turn with those instead. I JUST had to do this when I realized mine came without the stinking tool!
Juicer does not turn / rotate. Does this mean the motor is burnt out ?
It could mean burnt motor, but it could mean that it's simply got gunk in it, and it needs cleaning/lubricating. You'd have to take it apart to tell. A burnt motor has a very specific smell. If you take it apart, and there's no burnt smell, likely cleaning and lubricating will fix it.
13helpful
How do you take it apart to clean it ?
It's really easy, you take down the metal bar and the top comes off, then you should see the orange mesh basket which is removed using your little tool - it's like a key which you turn to remove the basket - rinse under the tap - piece of cake.
2answers
HOW DO I GET MY JUICER APART TO CLEAN IT
I looked all over for the disassembly instructions for the JM300 to no avail...so I got a flathead screwdriver and decided I'd either get the darned blade out or break it for good. It took some prying but the blade popped out and it was the RIGHT way to handle it after all. Now everything is clean and ready to use again.
Sep 14, 2009 • Juicers
Cant get it apart
I bought this machine in a garage sale and i cant seem to take it apart.
5helpful
2answers
How to take apart to clean?
use a large paper clip!!! I did and it worked.
A
1helpful
Taking Juicer apart
http://www.myeasypics.com/is.php?i=488929&img=jack_lalanne_operating_manual__0003.jpg
4helpful
How to clean blade and screen
First thing you need to do is take it apart, which can be done pretty simply until you get to the actual blade and strainer. You will need to use the crescent tool, the one with two pins. Insert it in the blade, and turn it counterclockwise while holding the filter so it doesnt turn. All the parts should come apart easily.
i find the best way to clean these parts is using a small brush, not a sponge or rag.
13helpful
6answers
Take apart and clean the juicer
ok so i am tryin to take apart my juicer to clean it but i can't find a way to do it. Can u help me?
Top Jack Lalanne Juicers Experts
ADMIN Andrew
ADMIN Andrew
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
